Signal for multiple PRI's with single 'D' Channel
tvanblon
Our old Mitel system would handle the signalling for all (3) PRI's over a single 'D' channel in the case of a 'D' channel failure on any of the 3 circuits. Do any of the Cisco gateways support this feature? It seems to be a common feature among many LECs.
pwarren
Yes. The feature you're looking for is called NFAS.
