03-16-2011 11:13 AM - edited 03-13-2019 07:21 PM
From a Cisco router running as CUBE I am able to send keepalives using SIP-OPTIONs message.
Can I enable a Cisco gateway to generate SIP re-INVITE messages as keepalives over a SIP trunk?
Solved! Go to Solution.
03-17-2011 08:23 AM
The SIP Session Timer Support feature adds the capability to periodically refresh Session Initiation Protocol (SIP) sessions by sending repeated INVITE requests. The repeated INVITE requests, or re-INVITEs, are sent during an active call leg to allow user agents (UA) or proxies to determine the status of a SIP session. Without this keepalive mechanism, proxies that remember incoming and outgoing requests (stateful proxies) may continue to retain call state needlessly. If a UA fails to send a BYE message at the end of a session or if the BYE message is lost because of network problems, a stateful proxy does not know that the session has ended. The re-INVITES ensure that active sessions stay active and completed sessions are terminated.
The SIP Session Timer Support feature also adds two new general headers that are used to negotiate the value of the refresh interval.
A Session-Expires header is used in an INVITE if the user agent client (UAC) wants to use the session timer.
The Minimum Session Expiration (Min-SE) header conveys the minimum allowed value for the session expiration.
Define a Min-SE on your cisco gateway with these commands:
Router(config)# voice service voip
Router(conf-voi-serv)# sip
Router(conf-serv-sip)# min-se 300
Defaults1800 seconds
Regards.
03-18-2011 10:39 AM
Yes, your analysis is right. The other end sip party doesn't support timer option.
The support of RFC4028 is not mandatory.
Regards.
04-04-2011 04:57 AM
I have looked into the issue and see that as per the restrictions of SIP
session timer feature Cisco SIP gateways cannot initiate the use of SIP
session timers, but do fully support session timers if another UA requests
it. This I guess if we don't see the "Session-Expires" field in SIP invite
sent from the Gateway as opposed that sent by CUCM, it is normal.
In fact the "supported" filed in SIP invite/2xx message from gateway shows
as below
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Presence of timer as an option confirms that it will support SIP session
timer feature. See the URL below for more details.
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_1369_p
s5640_TSD_Products_Configuration_Guide_Chapter.html
Instead we should see the session expires with refresher parameter in the
2xx (200 OK) message from the gateway to CUCM.
Now as far as your call scenario is concerned, in what direction are you
making the call? Can you please explain me the call flow as depicted
IP Phone>Gateway>SIP Trunk>CUCM>IP Phone.
I would assume that if the call is initiated from the Gateway side, it might
not support session timer as gateway will not initiate it.
03-17-2011 08:23 AM
Regards.
03-17-2011 08:58 AM
Thanks Daniele,
in fact I tested this command but I didn't see any re-invite after 300 s.
Then I went deeper in the RFC 4028, and I realized that the problem was at the other end.
According to this RFC, there must be a negotiation, but the other end didn't send the timer option flag on. So I guess Cisco router didn't enable SIP session timer as it was not negotiated:
Cisco 2811 sent:
INVITE sip:xxxxxxxxx@10.35.133.7:5060 SIP/2.0
Via: SIP/2.0/UDP 10.35.133.3:5060;branch=z9hG4bKD0D16DA
Remote-Party-ID: "Mati Gil" <550012037>;party=calling;screen=yes;privacy=off
To:
Date: Thu, 17 Mar 2011 11:35:52 GMT
Call-ID: 8C6AC335-4FC111E0-A268F89A-16BE1A5E@10.35.133.3
Min-SE: 1800
Cisco-Guid: 2355606997-1338053088-2724395162-381557342
User-Agent: Cisco-SIPGateway/IOS-12.x
Accept-Language: es
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1300361752
Contact: <550012037>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires: 1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 244550012037>
v=0
o=CiscoSystemsSIP-GW-UserAgent 7480 3143 IN IP4 10.35.133.3
s=SIP Call
c=IN IP4 10.35.133.3
t=0 0
m=audio 17592 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
*Mar 17 12:35:52: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.35.133.3:5060;received=10.35.133.3;branch=z9hG4bKD0D16DA
To:
CSeq: 101 INVITE
Content-Length: 0
Response from the other end (non-cisco SIP end), with no "timer" supported option:
Received:
SIP/2.0 200 OK
To:
CSeq: 101 INVITE
Contact:
Allow: SUBSCRIBE, NOTIFY, REFER, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK
Supported: 100rel
Content-Length: 203
v=0
o=- 3509350377 3509350378 IN IP4 10.35.133.7
s=ulnar
c=IN IP4 10.35.133.7
t=0 0
m=audio 7006 RTP/AVP 8 101
a=sendrecv
a=fmtp:101 0-16
What I don't see on INVITE message is the Session-Expires value. Is it mandatory? I find it when the invite comes from a Call Manager. Anyway, the other end doesn't seem to be RFC compliant.
03-17-2011 09:05 AM
Sorry,
I have attched the SIP Invite that initially comes from a Call Manager. The SIP INVITE that comes from the Cisco Gateway, where "session expire" is missing, is
Sent:
INVITE sip:xxxxxxxxx@10.35.133.6:5060 SIP/2.0
Via: SIP/2.0/UDP 10.35.133.2:5060;branch=z9hG4bK9525AA
Remote-Party-ID:
To:
Date: Thu, 17 Mar 2011 12:07:37 GMT
Call-ID: FBED7052-4FC511E0-9A56ABC6-77F3852E@10.35.133.2
Min-SE: 300
Cisco-Guid: 4226441970-1338315232-2163736601-1447633104
Accept-Language: es
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1300363657
Contact:
Expires: 180
Cisco-Gcid: FBEA62F2-4FC5-11E0-80F8-0019564920D0
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 4792 7274 IN IP4 10.35.133.2
s=SIP Call
c=IN IP4 10.35.133.2
t=0 0
m=audio 16518 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
03-18-2011 10:39 AM
Regards.
04-04-2011 04:57 AM
as below
04-26-2011 03:52 AM
The scenario is
Phone->PSTN networks->PRI ISDN E1 port->Gateway->SIP Trunk -> Third party SIP ACD
It seems the ACD does not respond with the apropiate timer options.
