SM-D-48FXS-E & SM-D-72FXS in cisco 29xx and 39xx ISR
mkhattab
Hello Support ,
I'm doing a configuration file on the cisco CWA tool for 3945E chassis and found neither of the 2 subject double wide modules are listed as possible options in the chassis . Purpose is to connect more than 40 analog modem to the ISR router . In other words what is the kitlist to have them connected  to the chassis , Thanks for your help
Brgds
Mohamed
paolo bevilacqua
Likely a configuration tool issue, that you have to bring to ordering tool support. You can order the parts as spare.
Note if you need the modem for PCs, you can use digital modedm cards, and COM software emulator.
Thanks Paolo , I've contacted the ordering support for that .... I actually need the modules to connect large volume of modems to an 3945 router and wanted to know the compatablity with the kitlist interms of slots and cards ( sort of sanity check )
Brgds
Mohamed
You are welcome.
Please remember to rate useful posts clicking on the star below.
