02-12-2021 02:39 AM
We are planning to buy wireless headset but found standard and multi base models in data sheet. whats the difference.
Solved! Go to Solution.
02-12-2021 02:48 AM
Hope you are looking for 500 series head phones
All features on base models Is available with multi base in addition it can Simultaneously connect to multiple physical and Bluetooth sources. Select a connection with the source selector buttons on the base station.
It pretty clearly mentioned in the data sheet.
02-12-2021 02:48 AM
