Stat counter for FXS cards
MattNicholls_2
I have a couple of FXS cards which allow calls to be sent to a stand alone IVR server. I'm trying to find a way to get a call count, successfule or not, sent to the router bound for the server. Since the only listing of the card is voice-port and typically all connections are viewed using a show voice .... command, I haven't been able to find a command that would show me a count like I normally would see a packet count on an interface.
If someone can point me in the right direction for command that would be great or is there a way to get this information off of the CCM running 4.1?
If you need more info to answer the question just ask.
Jesse Drohen
If you are using H323 and don't have other calls traversing this GW "show h323 gateway cause-codes" might give you what you are looking for.
Jesse
