switching between CCME and SDM
gurdjieff
Beginner
Beginner
I have a 2621XM running Callmanager Express and also have SDM on the same router. I cannot access CCME after installing SDM. All the correct files are still present.
Does anyone know what I am missing?
sbilgi
Contributor
Contributor
Which is the IOS version you are running. Try using 12.3T and see if it works.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a00801f12ab.html
Thanks. I spoke to TAC and it seems its a software bug so i've got to upgrade (heard that one before?).
The only issue is that the flash can't be squeezed in the 2600 so I have to flatten the whole router and tftp everything back on just to upgrade so will have to take that part of the network down for too long. I'm running a whole office through it, phones et al.
This is the problem with spaghetti coding devices.
