08-27-2015 01:54 AM - edited 03-13-2019 09:07 PM
I'v two networks with the same addresses. i'v been ask to find a the best way to connect them together without the use of a NAT.
And both of them will talk to an out side source...
Can some one help me?????
Michel Vaillancourt
08-27-2015 05:05 AM
You have a couple of (potential) issues here:
I'm assuming these sites are far apart, so a dark fiber run or some other bridge is out of the question.
My recommendation would be to bite the bullet and put a new IP scheme in at one of the sites. I would never look to bridge over WAN.
If you insist on carrying on then it's L2TP you need to use. I have no experience with that I'm afraid.
08-31-2015 12:49 AM
Thank's for your help.what is your opinion on configure Nat instead?
Michel vaillancourt
09-20-2015 10:17 PM
Michel,
You cannot use NAT between two networks with the same IP address range. NAT is process utilized by routers, routers only implemented between different networks. even if you forced router to connect similar networks it will not accept same ip address range on its different interfaces.
as jonallport said, you don’t have just bridging theory knowing that you will have conflicts as long as you are using the same ip address.
Hope that helps
12-19-2015 11:36 PM
Have you considered using bridge group or EVN?
I think best way to go is to change the IP addresses, but it's not always possible in a production environment.
