Timestamp removal in Bulk Edit Utility
admin_2
Level 3
Level 3
Do you have another update to the Bulk Edit utility for 2.4.6 that will set the before and after timestamps in conversation settings to false or off?<br><br>Thanks!!!<br><br>Adam W. Moore<br>CCNP, CCDA, MCP
Not applicable
Not currently... I'm in the process of releasing a few new 3.0 tools in the next couple weeks and then I intend to come back and do one final 2.x Bulk Update version (fix some bugs, add a few new features such as this) and then "freeze" the 2.x version of this tool. I'll be concentrating on making a 3.x specific version that goes right to SQL (about 10x faster than going through the directory) and revamping the interface a bit as well.
In general this will be the story for all the 2.x tools over the next month or two. I'll get one more shot at adding a few requested features and cleaning up a few sev 3 and 4 bugs and then freezing them where they stand. All new tools work will concentrate on 3.x specific development that works directly with SQL whenever possible. The increased speed and flexibility means I can do a lot more really nice stuff and maintaining two sets of tools across two different back ends is a little more than I can handle in my off hours.
Short story: get your 2.x tools feature requests in now.
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
