Community Helping Community
117
Highlighted
Beginner
Unity SA Not Running
When I launch Unity 4.0 Sys Admin page and click the Subcribers link, the browser session locks up. There are some MAPI and UMR failures in the event log. Am going back to see if there are permissions issues, but I did run syscheck and all was successful. Also, all was successful during the install. What else can I check?
1 REPLY 1
Re: Unity SA Not Running
If you are getting MAPI and UMR errors in the event log, there probably is a permissions issue. However, those errors don't reflect the SA problem; they reflect a different permissions issue.
Are you getting any errors/warnings from the AvDsGlobalCatalog or AvDSAD in the event log?
The SA problem may or may not be a permissions issue. You could try setting all of the AvSaDbConn traces, reproducing the problem and posting the AvCsMgr file here. The traces may or may not lead us to the problem, but it's a start.
Content for Community-Ad
FusionCharts will render here
