Urgent : Please advice!!
sting712
Dear support, I want to make a Qos of voice over frame relay ( 4 sites connected point -to - multipoint 256 kbps at main and 64 kbps for the three other sites )using routers 1601 and 805..
I want to configure the Following:
1-LLQ
2-Frame Relay traffic shaping
3-FR.12
4-cRTP.
Does the Qos of voice is supported by the image file "IP" or "IP Plus" ?
Does the Router 805 with IOS 12.2 (3) supports these features of Qos of Voice over frame relay ?
What is the suitable IOS for the 1601 that supports these four features of Qos of Voice over frame-relay and what is memory requirements on the 1601 for that??
Pleae advice as soon as possible , waiting for your answer to these questions.
smalkeric
Level 6
Level 6
Following are the Cisco IOS versions you can use for the Cisco 1600 series router with the featureset IP PLUS.
12.2(8)T
12.2(8)T8
12.2(8)T5
12.2(8)T4
12.2(8)T1
12.2(4)T
12.2(4)T5
12.2(4)T3
12.2(4)T1
12.2(2)T
12.2(2)T4
12.2(2)T1
12.2(15)T
12.2(13)T
12.2(13)T3
12.2(13)T1
12.2(11)T
12.2(11)T6
12.2(11)T5
12.2(11)T3
12.2(11)T2
12.2(11)T1
For the memory requirements and the different features, you can try different combinations of features and find out in which Cisco IOS the features/memory requiremetns are supported using the Software Advisor Tool available on www.cisco.com. The above list is a result of a search using this tool.
As far as the 805 Router is concerned, other than the frame relay traffic shaping, the rest 3 are supported. The IOS version supporting all the other features are given in the following page by the Software Advisor Tool:
http://www.cisco.com/cgi-bin/Support/CompNav/CN1.pl?HMajorRelease=&HFeatSelected=485%7C1048%7C681&HReleaseNumber=All&HReleaseId=-1&HPlatformFamilyName=805&HPlatformFamilyId=34&HFeatureSetName=NS&HFeatureSetId=0&HRN_Given=1&HPF_Given=0&HFS_Given=0&HRe...
Hope this makes sense.
