Using Linegroups within CCM4.0(2a)
s-butler
Using Linegroups:
Hi, I am using CCM4.0.2a and have configured Broadcast Linegroups/Hunt lists and Hunt Pilot points. Can anyone tell me if there is a way of adding Directory numbers to more than one Linegroup, or is it even possible?
When I try and add a new DN to an existing Linegroup, if the new DN is aleady within another Linegroup, the system will not see the new number?
Unfortunately I am unable to use a second line presentation on the user's phones as they use Cisco 7912s.
I would like to be able to have some directory numbers within more than one Broadcast linegroup. From what I can see on the system this does not appear to be possible?
Can anyone help?
thanks
Steve
pwlnw
It seems upgrade to 4.1 will help you.
http://cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00802e0689.html#wp1064966
Beginning with Release 4.1 of Cisco CallManager, a directory number may belong to more than one line group.
Hi, many thanks for informing me of that, I will look into to doing that to fix this issue.
regards,
Steve
