we installed a did vic in one of our offices and this is what we get from a debug voip ccapi inout when a call comes in. It does not ring on our side at all and the caller gets an immediate busy. The voice ports and the dial peers are both set to did and connected to the correct ports. Any help would be appreciated.
5d17h: cc_api_call_setup_ind (vdbPtr=0x82128454, callInfo={called=,called_oct3=0x81,calling=,calling_oct3=0x0,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=11, prog_ind=3},callID=0x81D582C8)
5d17h: cc_api_call_setup_ind type 24 , prot 0
5d17h: cc_process_call_setup_ind (event=0x820F4DF0)
5d17h: >>>>CCAPI handed cid 217 with tag 11 to app "DEFAULT"
5d17h: sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(217), disp(0)
5d17h: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(217), disp(0)
5d17h: ssaCallSetupInd
5d17h: ccCallSetContext (callID=0xD9, context=0x8226B780)
5d17h: ssaCallSetupInd cid(217), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
5d17h: ssaCallSetupInd finalDest cllng(....), clled()
5d17h: ssaCallSetupInd cid(217), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result= -1
5d17h: ccCallDisconnect (callID=0xD9, cause=0x1 tag=0x0)
5d17h: cc_api_call_disconnect_done(vdbPtr=0x82128454, callID=0xD9, disp=0, tag=0x82295F1C)
5d17h: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(217), disp(0)
5d17h: cid(217)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(1)
