VIDEOCONFRENCING DESIGN GUIDE POSTED AT....
aglowack
19 Replies 19
rgmasbad
I didn't find the design guide where you said it will be located. What is the filename?
I just went there and found it again, do you have a CCO login? Here is the link, but I am not sure if it will work since a password is required to access the Partner-E-Learning connection? If you get into the partner E learning page and search on videoconferencing srnd from it comes up. Here is the link http://cisco.partnerelearning.com/pec/main.asp?Nav=EmpHome&Body=ingtoday%2Easp&Task=1&ObjID=88502
If you still can't get to it give me your email address and I will email the document to you.
Please send me this document.
mcmullen@emstechnologies.ca
I couldn´t find it aty PEC. Anyway, could you mail me the document?
mschuler@ieee.org
Please email to me a copy
Thank
My email: tung_tran@saigonpostel.com.vn
I can't get in, can you email me the document? Thanks
keithharrismcp@aol.com
Please email me the videoconference design guide.
my email: elhedwin@cantv.net
Sorry about the last message, that wasn't my email.
Hi Aglowack:
I do not have a level 3 or level 7 access to access that document you mentioned thro the URL/WebSite.
So could you please mail me the document or better still is there any public space in the forums area that is accessible to everyone ??? My mail ID is cryant@umich.edu
Thanks in advance
Raj
richard.evans
It appears that you must be a higher level partner to be able to get into this portion of the site. Level 1 and 2 get you nothing.
m.schuler
Could you please describe the section where the paper is located?
I couldn´t found it at PEC e-learning connection...
