03-14-2011 02:13 PM - edited 03-01-2019 06:55 AM
I have found this question in a Q&A of the Cisco Nexus 5548P:
Q. Does the Cisco Nexus 5548P support 1 Gigabit Ethernet ports?
A. All Ethernet ports on the Cisco Nexus 5548P, including the Ethernet ports on expansion modules, are hardware
capable of supporting both 1 and 10 Gigabit Ethernet speeds. Software support for 1 Gigabit Ethernet will be
available in a future software release.
Is it right that today I can not use 1 Gigabit Ethernet speed on the Nexus 5548P?
Thanks and best regards.
Solved! Go to Solution.
03-14-2011 09:52 PM
With the recent release, 5.0(3)N1(1) you can now use the ports in 1-Gig mode as well by inserting one of the supported SFPs.
Atif
03-14-2011 09:52 PM
Atif
03-15-2011 12:56 AM
Hi Atif,
thank you. I found the answer in the Release Notes.
Have a great day...
