2 N5k with one Core switch
smartboy2255
Dear all,
   I have two N5K and one core switch.I have conected my two N5K with one Core Switch as per diagram attached.If I connect both redundant link to core switch my traffic is not going properly .As per the debug ip packet traffic is going to peer link and getting dropped instead of Core uplink.Kindly help...
7 Replies 7
Derek Zhang
You probably need to describe the issue more specifically,
which vlan, ip header, inter-vlan routing issue or same vlan traffic?
Where is the default gateway? any HSRP protocol enabled?
vpc have the protection to drop the packet has non-local mac and traverse via the peer-link.
http://www.jeremyfilliben.com/2010/08/hsrp-vpc-and-vpc-peer-gateway-command.html
but not sure the exact issue you have.
Hi Dazhi,
    Pls find the attached config of my network  eg:.I am trying to SSH to my Primary nexus IP (vlan 133 ip) , i am able to access. But same time if try to access secondary nexus IP (vlan 133). it wont happen.sometimes it will happen viceversa.VPC details I have shared in the diagram. But from the host connected from my nexus 5K i am able to reach all IP's.
I have done debug on both nexus , during the issue packect will forward to port channel 10 (peer link) and getting dropped instead of forwarding to vpc 20.
pls help..
Ajith
Primary Nexus Config :
NexusPrimary#
NexusPrimary#
NexusPrimary#
NexusPrimary# sh run
!Command: show running-config
!Time: Sat Sep 24 11:31:16 2011
version 5.0(2)N2(1)
feature fcoe
no feature telnet
no telnet server enable
no feature http-server
cfs eth distribute
feature udld
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$kxVjQ5Q7$QEbkT8giP8aRgq7Om800a1  role network-admin
username cisco password 5 $1$JJEua1eA$pDJ0d8VQiEZVU4nR2HxAw/  role network-opera
tor
no password strength-check
[7m--More-- [m
ip domain-lookup
ip domain-lookup
hostname NexusPrimary
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
fex 101
  pinning max-links 1
  description "***N2K-Pri2K***"
fex 102
  pinning max-links 1
  description "***To -SEC2K**"
[7m--More-- [m
snmp-server user admin network-admin auth md5 0x3c47e8ce70ceb780b7ec0ccac5ac08be
priv 0x3c47e8ce70ceb780b7ec0ccac5ac08be localizedkey
snmp-server user cisco network-operator auth md5 0x3d19380b8d99a3b36e269a32ef72a
c3b priv 0x3d19380b8d99a3b36e269a32ef72ac3b localizedkey
snmp-server enable traps entity fru
vrf context management
  ip route 0.0.0.0/0 10.10.10.2
vlan 1,130,133
vpc domain 133
  role priority 4096
  peer-keepalive destination 10.10.10.2 source 10.10.10.1
interface Vlan1
  no shutdown
interface Vlan130
  no shutdown
interface Vlan133
  no shutdown
  ip address 10.100.133.37/24
[7m--More-- [m
[K
interface port-channel10
  switchport mode trunk
  vpc peer-link
  spanning-tree port type network
  speed 10000
interface port-channel20
  description ***Uplink to CoreSwitch***
  vpc 20
  speed 1000
interface port-channel30
  description ***Uplink to EMC***
  vpc 30
  speed 10000
interface port-channel40
  description ***Uplink to EMC2***
[7m--More-- [m
  vpc 40
  speed 10000
interface port-channel101
  description ***CONNT-N2K-1SEC***
  switchport mode fex-fabric
  vpc 101
  fex associate 101
interface port-channel102
  description ***CONNT-N2K-2SEC***
  vpc 102
  fex associate 102
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
[7m--More-- [m
[K
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
interface Ethernet1/1
  speed 1000
  channel-group 20
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
[7m--More-- [m
[K
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
[7m--More-- [m
  speed 1000
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
[7m--More-- [m
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
  description Connected to Nexus 5K
  channel-group 10 mode active
interface Ethernet1/32
interface Ethernet2/1
  description ***FEX 102***
  fex associate 102
[7m--More-- [m
  channel-group 102
interface Ethernet2/2
  description ***Fex 101***
  fex associate 101
  channel-group 101
interface Ethernet2/3
  channel-group 30 mode active
interface Ethernet2/4
  channel-group 40 mode active
interface Ethernet2/5
interface Ethernet2/6
[7m--More-- [m
interface Ethernet2/7
interface Ethernet2/8
interface mgmt0
  ip address 10.10.10.1/30
interface Ethernet101/1/1
  switchport access vlan 133
interface Ethernet101/1/2
  switchport trunk native vlan 133
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
[7m--More-- [m
[K
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
[7m--More-- [m
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
interface Ethernet101/1/20
[7m--More-- [m
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
interface Ethernet101/1/27
[7m--More-- [m
[K
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
interface Ethernet101/1/33
interface Ethernet101/1/34
[7m--More-- [m
interface Ethernet101/1/35
interface Ethernet101/1/36
interface Ethernet101/1/37
interface Ethernet101/1/38
interface Ethernet101/1/39
interface Ethernet101/1/40
interface Ethernet101/1/41
interface Ethernet101/1/42
[7m--More-- [m
interface Ethernet101/1/43
interface Ethernet101/1/44
interface Ethernet101/1/45
interface Ethernet101/1/46
interface Ethernet101/1/47
interface Ethernet101/1/48
interface Ethernet102/1/1
[7m--More-- [m
[K
interface Ethernet102/1/2
interface Ethernet102/1/3
interface Ethernet102/1/4
interface Ethernet102/1/5
interface Ethernet102/1/6
interface Ethernet102/1/7
interface Ethernet102/1/8
[7m--More-- [m
interface Ethernet102/1/9
interface Ethernet102/1/10
interface Ethernet102/1/11
interface Ethernet102/1/12
interface Ethernet102/1/13
interface Ethernet102/1/14
interface Ethernet102/1/15
interface Ethernet102/1/16
[7m--More-- [m
interface Ethernet102/1/17
interface Ethernet102/1/18
interface Ethernet102/1/19
interface Ethernet102/1/20
interface Ethernet102/1/21
interface Ethernet102/1/22
interface Ethernet102/1/23
[7m--More-- [m
[K
interface Ethernet102/1/24
interface Ethernet102/1/25
interface Ethernet102/1/26
interface Ethernet102/1/27
interface Ethernet102/1/28
interface Ethernet102/1/29
interface Ethernet102/1/30
[7m--More-- [m
interface Ethernet102/1/31
interface Ethernet102/1/32
interface Ethernet102/1/33
interface Ethernet102/1/34
interface Ethernet102/1/35
interface Ethernet102/1/36
interface Ethernet102/1/37
interface Ethernet102/1/38
[7m--More-- [m
interface Ethernet102/1/39
interface Ethernet102/1/40
interface Ethernet102/1/41
interface Ethernet102/1/42
interface Ethernet102/1/43
interface Ethernet102/1/44
interface Ethernet102/1/45
[7m--More-- [m
[K
interface Ethernet102/1/46
interface Ethernet102/1/47
interface Ethernet102/1/48
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.2.N2.1.bin
boot system bootflash:/n5000-uk9.5.0.2.N2.1.bin
ip route 0.0.0.0/0 10.100.133.1
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
[7m--More-- [m
[K
NexusPrimary#
NexusPrimary#
Secondary Nexus:
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary# sh  [J  [Jter len 0
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary# sh run
!Time: Sat Sep 24 11:30:21 2011
version 5.0(2)N2(1)
feature fcoe
no feature telnet
cfs eth distribute
feature udld
feature lacp
feature vpc
feature lldp
feature fex
username admin password 5 $1$XAcql/pI$rgo509TPZA6LhdRDHKjBG/  role network-admin
ip domain-lookup
ip domain-lookup
hostname NexusSecondary
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
fex 101
  pinning max-links 1
  description "***FEX 101***"
fex 102
  pinning max-links 1
snmp-server user admin network-admin auth md5 0xd07e8beae6b3a0324a6e55ea455e7309 priv 0xd07e8beae6b3a0324a6e55ea455e7309 localizedkey
  ip route 0.0.0.0/0 10.10.10.1
vlan 1,130,133
vpc domain 133
  role priority 8192
  peer-keepalive destination 10.10.10.1 source 10.10.10.2
interface Vlan1
  no shutdown
interface Vlan130
  no shutdown
interface Vlan133
  no shutdown
  ip address 10.100.133.38/24
  vpc peer-link
  speed 10000
  vpc 20
  speed 1000
  vpc 30
  vpc 40
  vpc 101
  fex associate 101
  vpc 102
  fex associate 102
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
  speed 1000
  channel-group 20
  speed 1000
  fex associate 102
  channel-group 102
  fex associate 101
  channel-group 101
interface mgmt0
  ip address 10.10.10.2/30
  switchport access vlan 130
line console
line vty
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
interface fc2/5
interface fc2/6
interface fc2/7
interface fc2/8
NexusSecondary#
NexusSecondary#
NexusSecondary#
NexusSecondary#
So your problem is:
All hosts under Fex in same vlan 133 can ssh/ping both Nexus SVI.
But host behind(in same vlan or different vlan?) Nortel Core switch  or Nortel Core Switch SVI ssh Nexus SVI failed
you need to konw the ssh src/dst-mac, src/dst-ip of the failure/successful scenario.
And check the path of the fowarding/return path of the ssh packet.
From the debug you mentioned, it seems to me the source of the ssh mac address is learnt via peer-link instead of directly connectted vpc 20 locally.
Or better a TAC case to address all the question above.(also possible bug).
Hi Dazhi,
      I have some restriction to raise the TAC..I am suspecting the problem is deisgn. Is it possible to connect my two uplinks from Nexus 5K to my Core Switch ?If possible whether we need to bind both in same VPC ?Can you pls share me some sample template and diagram with one core switch.
Ajith
This documentation is a good desigh example with vpc yes-or-no:
http://bradhedlund.com/2010/12/16/routing-over-nexus-7000-vpc-peer-link-yes-and-no/
binding 2 uplinks(need in same vpc x)  to core switch (single Etherchannel) is supported.
E.g.:
Core Switch(example by using cisco switch)
interface port-channel 1
switich mode trunk
interface Te1/1
channel-group 1 mode active
interface Te1/2
N5K1: (Eth1/1 <-> Te1/1 on Core)
vpc 1
interface ether 1/1
N5K2:(Eth1/1 <-> Te1/2 on Core)
inter port-channel 1
vpc 1
interface ether 1/1
chann-group 1 mode active
some more reference:
http://docwiki.cisco.com/wiki/Nexus_5000_vPC_Design_Best_Practices
