Highlighted
Beginner
About checkpoint and rollback
Hi everybody:
I see the checkpoint command very useful to work in my lab
But depending what configuration do you made sometimes doesn't work
Somtime I get this error: "Rollback Patch is not Empty"
I was googling it but with no success
Any help will be aprreciate
Al
1 REPLY 1
Highlighted
Rising star
Have a look at this post
http://deepakarora1984.blogspot.com.au/2012/10/nexus-configuration-roll-back-using.html
"Rollback patch is empty. Which mean Checkpoint config is the same as current running-configuration."
I'm guessing therefore that not emplty means that there is a difference between the two.
Don't forget to rate all posts.
Content for Community-Ad
