Alert forwarding in DCNM 7.0.2
mike.ward27
I have an issue with DCNM 7.0.2 new install. When configuring event forwarding via email only events that are generated with the severity 'Warning' are forwarded on. Everything else appears to be ignored.
Has ansone come across this issues.
All mail settings are correct and test work fine, Have generated 100 warnings by shutting down all VPC ports and I get all those alerts. However if I shout down the VPC peer link I dont get the errors or criticals. Even if I set the alert forward to critical and above.
luuvuonglinh
Hi Mike !
Can you help me ? I need your help
I can't find the way to send an email alert . All mail setting are correct , but when i click "Apply and test" , nothing happen ? i can send a report , but email alert is not
Can you send alert with these event ?
-Interface goes down
-CPU higher than threshold
Please help me , my email is : luuvuonglinh@gmail.com
Thank you so much
