11-17-2014 09:03 AM - edited 03-01-2019 07:43 AM
I was looking to configure anycast HSRP on our 2 Nexus 5596 switches and while looking at some of the documentation, I came across some limitations mentioned for Nexus 7000 ( http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/verified_scalability/b_Cisco_Nexus_7000_Series_NX-OS_Verified_Scalability_Guide.html ).
In the link above, it was mentioned that the number of Anycast HSRP bundles supported is 64 ( verified limit). I tried to search for a similar document regarding Nexus 5000s and couldn't find any documentation. It would be really helpful if anyone has any idea of the maximum number of bundles that a Nexus 5596 running [7.0(5).N1].
Arun
04-23-2015 06:12 AM
I am also looking at this, were you able to find an answer?
04-24-2015 07:20 AM
Hello @jonathansams,
Yes, the max number of bundles is 10. I don't have the document with me, but I did read that 5k's were only capable of going up to 10.
Arun
04-29-2015 08:07 AM
THank you fro your reply.
