Showing results forĀ
Search instead forĀ
Did you mean:Ā
Bug CSCun57894
we have N7k 2pcs and we have faced an
issue as bellow and i found its a bug on IOS 6.2.12 is there any soloution to solve this issue?
016 Jul 15 22:08:42 -B ospf[4803]: Warning! Malloc Failure in
../routing-sw/libs/timers/active_timer.c[927] for size 8196
2016 Jul 15 22:08:41 -B %OSPF-3-ATIMERS_ERROR: malloc failed in
heap_create
2016 Jul 15 22:08:41 -B %OSPF-3-ERROR: -Traceback: librsw.so+0xe1b85
librsw.so+0xd902e libospf.so+0x19f078 libmtrack.so+0x5437
libmtrack.so+0x9850
libutils.so+0x12c03 libospf.so+0x23a020 libutils.so+0xd093
libutils.so+0xedb7 libospf.so+0x232a32 libospf.so+0x24256b libospf.*
2016 Jul 15 22:08:41 -B %OSPF-1-LOWMEM: ospf-100 [4803] Low memory
condition: Shutting down the OSPF process. Please restart OSPF manually
2016 Jul 15 22:08:42 -B ospf[4803]: Warning! Malloc Failure in
heap_create
librsw.so+0xd902e librsw.so+0xd8cd5 librsw.so+0xd9001 libospf.so+0x19f078
lib
mtrack.so+0x5437 libsdwrap.so+0x9796 librsw.so+0xe19e2 librsw.so+0xd902e
libospf.so+0x2425bd libospf.so+0xeedbb 0x8054817 0x807*
2016 Jul 15 22:08:41 -B %OSPF-4-SYSLOG_SL_MSG_WARNING: OSPF-1-LOWMEM:
message repeated 1 times in last 17418055 sec
heap_create
librsw.so+0xd902e libospf.so+0x2425bd libospf.so+0xeedbb 0x8054817
0x8070704
0x807bb0a 0x807f740 libospf.so+0x973a2 librsw.so+0xaa81f
libpthread.so.0+0x6140 libc.so.6+0xcedee
2016 Jul 15 22:08:41 -B %OSPF-3-TLV_INTF: ospf-100 [4803] Failed to
convert to TLV for x.x.x.x (0x1)x.x.x.x (0x80006c80) (0x3333) (4)
Hi Amirkia,
You can check the release notes of the target version and see the list of Open caveats. See if those caveats affect your existing setup and if their impact your setup more than the current bug that you are hitting. See, its very rare to have a version with no defects, its just a continuous cycle to upgrade the software/hardware to add new features, bug fixes.
Manish
- Do rate helpful posts -
Manish Gogna
Hi Amirkia,
Since there is no workaround for the bug you may try upgrading to one of the fixed versions.
Manish
Hi Manish,
im not sure after upgrading I will face another issue cause I have checked 6.2.14 and it has more bug in comparison 6.2.12
do you have any recommendation ?
thx for your kind help and support
Amirkia
Hi Amirkia,
Manish
Hi Manish,
as I checked suggested ios is 6.2(16) and it seems all the bugs have been fixed on this release .
BR
Amirkia
