Built-in Wireshark in Nexus 7000
mmrrittner
hello togehter,
I have problem to capture data from the built-in ethanalyzer (wireshark) on a USB flash or Bootflash when the capture size reach 10MB. I tested with NX 4.2.4 and 5.0(2a). Is anyone know this issue?
how can I extended the capture size on the flashs?
best regards
michael
mmrrittner
Hello togehter,
I find the white-paper document for built-in wireshark on the Nexus 7010 self. the write option is limited to 10 MB.
you can start the analyzer with NX-OS# ethanalyzer local interface inband limit-capture-frame write
It is possible disabled the limitation?
best regards
michael
Ganesh Hariharan
hello togehter,
best regards
michael
Hi Michael,
As per the link i suppose capture file size is limited to 10 MB in nexus 7000
http://www.ciscosystems.com.ro/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/white_paper_c11-554444.html
Hope to Help !!
Ganesh.H
If helpful do rate the helpful post
hello ganesh,
do you know how I can disable the limitation when I use a usb flash, maybe a hidden command?
or plant cisco to extended the file size. In this case I will only sniffer the arp traffic which is running in the control plane policy for a longer time.
best regards
michael
