Callhome in every VDC or just Admin VDC?
dtushing123
Level 3
Level 3
Guys,
Are you configuring Callhome in every VDC or just the admin VDC?
I'm wondering if I'm getting anything useful out of having a separate Callhome configuration in all 3 of my VDC's.
I'm not using CFS to distribute either, I also wonder if I should just put NTP only in the admin VDC?
Is there a "banner exec" command available on NX-OS - 5.1.4?
Jerry Ye
1. Smart Callhome should be only needed in the default VDC, hardware issue will only be able to reported by the default VDC. Here is the link for reference:
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_6callhome.html#wp1059821
2. CFS is needed for vPC. Do you mean to use CFS for Smart Callhome???
3. NTP is only configurable in default VDC.
4. banner exec doesn't exist in NXOS.
HTH,
jerry
Hey Jerry,
Okay great that makes sense. Yes I do have CFS enabled for vPC
Thanks for the answer
Darren
