Showing results forĀ
Search instead forĀ
Did you mean:Ā
can we use SVI as peer link on 5K?
sidranetwork
can we use SVI as peer link on cisco Nexus5548 Chassis?
? or only management interface will work?
If we can use SVI can we use the switch-profile?
If yes we are having the problem with switch-profile syncronization and we are using the SVI as peer link.
switch-profile  : 5kpeer
Start-time: 253279 usecs after Thu Aug 29 07:54:08 2013
End-time: 447786 usecs after Thu Aug 29 07:54:10 2013
Profile-Revision: 15
Session-type: Commit
Session-subtype: -
Peer-triggered: No
Profile-status: Sync Success
Local information:
Status: Commit Success
Error(s):
Peer information:
IP-address: 1.1.1.10
Sync-status: Not yet merged
Merge Flags: pending_merge:1 rcv_merge:0 pending_validate:0
Status: Peer not reachable
Error(s):
Same is the output for another switch
sh run vpc
!Command: show running-config vpc
!Time: Thu Aug 29 08:13:03 2013
version 5.0(3)N2(1)
feature vpc
vpc domain 4
  role priority 100
  peer-keepalive destination 1.1.1.10 source 1.1.1.9 vrf KEEPALIVE
  peer-gateway
interface port-channel10
  vpc peer-link
interface port-channel31
  vpc 31
interface port-channel101
  vpc 101
interface port-channel102
  vpc 102
Please suggest the next step
Pawan
Hafiz Butt
Please follow thee steps to configure vPC on Cisco 5000 Series Switch 1 shown in Figure 4.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
Hope this may helful to you
