10-13-2016 08:16 AM - edited 03-01-2019 08:23 AM
Community,
I have a Nexus C2248TP-1GE uplinked to a Nexus 9K, when I try to enable Auto-MDIX on the FEX port I get the following error:
QTS-AGG-1B(config)# int eth104/1/11
QTS-AGG-1B(config-if)# mdix auto
ERROR: Ethernet104/1/11: requested config change not allowed
The reason im trying to enable this is because we have certain servers that when plugged into the port, the port does not come up on the FEX but when we plug a laptop into it, it works fine. These 2K's are single homed so the issue with the interface configs needing to be the same in both core 9K's I believe is avoided.
Any thoughts?
Thanks.
Solved! Go to Solution.
10-13-2016 08:58 AM
Yes its not supported looking at its capabilities on my fexs , 2232 model is the same
5ks don't have the command either when I check
maybe you just need a crossover ?
# sh interface Ethernet101/1/23 capabilities
Ethernet101/1/23
Model: N2K-C2248TP-1GE
Type (Non SFP): 10/100/1000BaseT
Speed: 10,100,1000,auto
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: no
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: none
QOS scheduling: rx-(6q1t),tx-(1p6q0t)
CoS rewrite: no
ToS rewrite: no
SPAN: yes
UDLD: no
MDIX: no
Link Debounce: yes
Link Debounce Time: yes
dot1Q-tunnel mode: yes
Pvlan Trunk capable: yes
TDR capable: no
FabricPath capable: no
Port mode: Switched
FEX Fabric: no
10-13-2016 08:58 AM
Ethernet101/1/23
Duplex: full
Channel: yes
Rate mode: none
CoS rewrite: no
ToS rewrite: no
SPAN: yes
UDLD: no
MDIX: no
Link Debounce: yes
TDR capable: no
Port mode: Switched
FEX Fabric: no
10-18-2016 08:12 AM
Thanks for the clarification Mark!
