Cat 6509 to N5K
dmooregfb
Level 5
Level 5
I am wanting to connect the Cat 6509 to the N5K using 4 - 1Gb ports channeled. My question is - do I need to configure the Interface Port-Channel XX on both switches and apply to the interfaces?
dave
mizhang
Hi -
Configuring the port-channel on N5K shoud not be any different than in other Cisco Cat switch.  In case you configure vPC, you can check out the following doc as a referenece.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
Michael
