Change HyperFlex Cluster node IP address?
SIMMN
Say I have an existing HX cluster with VMware with following networks configured (Standard virtual switch):
  1. Storage Controller Data Network (VLAN 6)
  2. Storage Controller Management Network/ESXi Management (VLAN 4)
  3. vMotion (VLAN 5)
  4. Guest VM Networks (VLAN 101 and 101)
Now I need to change #2&3 above to different VLANs and subnets...I understand the vMotion one should be relatively easier to change but I am concerned about changing #2...I do plan to turn off the cluster for the change.
Anyone has experience of such tasks and could help: Can this be done for an existing HX cluster? If so, what should be the proper order of operation and what level of impact there would be?
Thanks!
SIMMN
Anyone, still looking for suggestions.
