Changing SSL to IPSec in ASA5510
Michael Seden
I've got a Data Center with an ASA5510, which has both a SSL tunnel for AnyConnect and an IPSec tunnel going to an ASA5505 at the Office in the outside interface.
For remote users with ASA5505's I've got two tunnels built, one to the DC and one to the office. No problems, can talk to both locations. For users that have to use Anyconnect, there is seamless access to the data center, but when the IP/TCP and  SSL headers are removed, and the ASA see's it is going to the office, is in not getting re-incapsulated by IPSec to go back out the IPSec tunnel.
Has anyone encountered this and is there a solution?
Mike Seden
Business Technology Architects
ROBERTO TACCON
Level 4
Level 4
Which software version are you using ?
check this BUG CSCty32412
https://supportforums.cisco.com/thread/2149125
ASA: Anyconnect u-turn to ipsec tunnel fails
Symptom:
ASA after a upgrade to 8.4.3.1 or later, anyconnect traffic that will uturn (hairpin) to a ipsec lan
to lan tunnel is dropped.
The show asp drop shows the following reason:
Expired VPN context (vpn-context-expired)
No log message is generated for the drops.
Issue is seen on ASA 8.2.5.26 as well
Conditions:
Anyconnect client uturns into a ipsec lan to lan tunnel.
Fixed-In
8.4(4)
9.0(1)
9.1(1)
9.0(0.99)
8.4(3.105)
100.8(33.3)M
100.8(0.126)M
8.2(5.29)
100.7(13.73)M
100.7(6.78)M
100.8(11.20)M
100.9(2.1)M
100.8(27.7)M
100.9(0.1)M
8.4(4.99)
100.8(34.1)M
5 Replies 5
micturne
Level 4
Level 4
Thanks for posting Mike and great use of whiteboard shots.  I'll run this one by the megaminds and see what we can find for you.
I'm glad there is a mega-mind out there because mine is fixin' to explode! I am just about ready to start a TAC case with it. I would be glad to share configs if needed, but will have to go through the 'Change' Procedure to make any. Thanks for your reply and letting me know that there is hope. My Obi-Wan makes me whiteboard everything....
ROBERTO TACCON
Level 4
Level 4
Symptom:
Conditions:
Fixed-In
8.4(4)
9.0(1)
9.1(1)
9.0(0.99)
8.4(3.105)
100.8(33.3)M
100.8(0.126)M
8.2(5.29)
100.7(13.73)M
100.7(6.78)M
100.8(11.20)M
100.9(2.1)M
100.8(27.7)M
100.9(0.1)M
8.4(4.99)
100.8(34.1)M
I see that ASA version 8.4(3)8 is what is currently running.
I used the bugtool to see what was what, and the powers that be decided we need to upgrade. Our current version definately hits in the bug zone. Thank you so much for your help.
