Cisco DCNM Template assistance
junajunction
Hi Guys,
Need support in creating a DCNM deployment template for creating or renaming a layer 2 vlan on the nexus switches.
I was able to find the below two templates, but neither of them seem to be working. Where the first template is validated and gets deployed successfully but the change is not reflected on the switch or configuration change on the switch does not occur. and the Second template fails in validating the template and gives errors.
First Template:
##template variables
# Copyright (c) 2018 by Cisco Systems, Inc.
# All rights reserved.
@(PrimaryAssociation=true, IsMandatory=true)
integer vlan;
@(IsMandatory=false, DisplayName="Name")
string nme;
##template content
vlan $$vlan$$
if($$nme$$ !=""){
name $$nme$$
Second Template:
integerRange vlan_range;
@(internal=true)
integer vlanName;
##template content
foreach vlanID in $$vlan_range$${
vlan @vlanID
$$vlanName$$=@vlanID
name myvlan$$vlanName$$
Thank you all
0 Replies 0
