06-24-2020 06:59 AM
Hi , I have to do install an HCI with 5+1 nodes . It's and standard cluster . Please provide me helpful document to go through.
Solved! Go to Solution.
06-24-2020 07:23 AM
here is pre-check list :
resources :
07-04-2020 02:05 AM
here is some reference :
06-24-2020 07:23 AM
resources :
07-04-2020 01:26 AM
I Have implemented standard cluster for 5+1 node, now customer want to migrate his v center for this cluster .
Is it possible, kindly share any document if available.
07-04-2020 02:05 AM
07-12-2020 10:20 AM
07-12-2020 10:36 AM
Greetings.
Yes, you can use 10Gb SFP, but please check the spec sheet to make sure your SFPs are listed: https://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/6400-specsheet.pdf
If you have only one network uplink port, you don't need a port-channel.
However, it would make it easier later on to add additional ports, if you already have the port-channel defined now, even if it is only with one link.
Kirk...
