353
meiercyrill
Beginner
CISCO LISP + GETVPN RLOC interface in VRF
I’am a student making an apprenticeship.
My current task is to create a new VPN LAB environemente.
I have to compare DMVPN Phase 3 with Cisco LISP + GETVPN.
Thanks to the Cisco GETVPN+LISP Lab Guide I was able to build a quiet good lab.
But there is no MGMT routing separation. I want to have Loopback 0 interface and the interface facing to the RLOC to be vrf forwarding to MGMT.
But then LISP stopped working.
I was searching for a solution and I tried to vrf forwared the Lisp Interface , which did not worked out for me.
I didn't quiet get what those 2 commands are supposed to do.
Ip lisp source-locator
Ipv4 alt-vrf
Is it even possible to pop the interface facing to the RLOC into an other vrf?
Thanks for your help, I really appreciate it.
0 REPLIES 0
