02-02-2019 08:10 AM - edited 03-01-2019 08:51 AM
Since the whole management console for Cisco Meraki in Cloud. Is that mean the control plane will be in cloud and the data plane will stick with devices itself. Which is leads us to SDN concept in some how ?
Thank you,
02-02-2019 08:15 AM
Its semi kind of, but this for SME will be good, for full Enterprise solution i will still stick with WLC and WAP.
here is good reference for you :
https://meraki.cisco.com/lib/pdf/meraki_datasheet_cloud_management.pdf
02-02-2019 08:18 AM
So how we can confirm that ? It seems to be yes the control plane in cloud. But any why to prove that ?
02-02-2019 08:26 AM
02-02-2019 08:30 AM
02-02-2019 02:23 PM
With regard to WiFi; I wouldn't. We are down to doing only maybe 1 WLC deployment a year. All the rest are now Cisco Meraki.
Basically we only do WLC deploymenyts now if the site has to operate permanently with no Internet connection.
02-02-2019 02:21 PM
It would be more accurate to say the management plane is in the Cloud.
For example, lets take a Cisco Meraki Switch. If you disconnect it from the Internet it will keep forwarding/routing packets, however you will loose the ability to make config changes (and to monitor it).
02-02-2019 03:34 PM
02-02-2019 06:40 PM - edited 02-02-2019 06:41 PM
On the device; As Philip D'Ath mentioned,if you disconnected from Cisco Meraki, it will keep working.
That's mean the mac address table, spanning tree process...etc are processed on local device instead of cloud.
Compared with SDN (let's say ACI), the control plane and management plane are really processed on the APIC (the controller). The device only process the data plane (imagine a single ip-to-port table for every switch/router, they only do table lookup to forward packet). Controller is responsible to handle control plane traffic, if the controller is down, the network infrastructure is down. Obviously, Cisco Meraki not doing the same thing.
02-08-2019 12:15 PM
hIf you disconnect it from the Internet it will keep forwarding/routing packets, however you will loose the ability to make config changes (and to monitor it). https://audacity.onl/ https://findmyiphone.onl/ https://origin.onl/
