cisco meraki Data plane and control plane
Dhari Kh
Since the whole management console for Cisco Meraki in Cloud. Is that mean the control plane will be in cloud and the data plane will stick with devices itself. Which is leads us to SDN concept in some how ?
Thank you,
10 Replies 10
balaji.bandi
Its semi kind of, but this for SME will be good, for full Enterprise solution i will still stick with WLC and WAP.
here is good reference for you :
https://meraki.cisco.com/lib/pdf/meraki_datasheet_cloud_management.pdf
BB
So how we can confirm that ? It seems to be yes the control plane in cloud. But any why to prove that ?
Hi all,
I have a question about it.. Is the "control plane" mentioned on the above link is actually the management plane only? The control plane traffic like OSPF / STP...etc are processed on device instead of cloud? If so, then it's different from the concept of SDN, am I right?
This is exactly what I mean ..
With regard to WiFi; I wouldn't.  We are down to doing only maybe 1 WLC deployment a year.  All the rest are now Cisco Meraki.
Basically we only do WLC deploymenyts now if the site has to operate permanently with no Internet connection.
gnc20
It seems to be yes xender  discord  omegle
Philip D'Ath
It would be more accurate to say the management plane is in the Cloud.
For example, lets take a Cisco Meraki Switch.  If you disconnect it from the Internet it will keep forwarding/routing packets, however you will loose the ability to make config changes (and to monitor it).
Ok good deal . But how about the control Plane where will be ?
On the device; As Philip D'Ath mentioned,if you disconnected from Cisco Meraki, it will keep working.
That's mean the mac address table, spanning tree process...etc are processed on local device instead of cloud.
Compared with SDN (let's say ACI), the control plane and management plane are really processed on the APIC (the controller). The device only process the data plane (imagine a single ip-to-port table for every switch/router, they only do table lookup to forward packet). Controller is responsible to handle control plane traffic, if the controller is down, the network infrastructure is down. Obviously, Cisco Meraki not doing the same thing.
hIf you disconnect it from the Internet it will keep forwarding/routing packets, however you will loose the ability to make config changes (and to monitor it).   https://audacity.onl/ https://findmyiphone.onl/ https://origin.onl/
