01-15-2015 08:56 AM - edited 03-01-2019 07:46 AM
Dear Team,
I am using Cisco 5548P and is running with image 5.0(2)N2(1) and now we need to upgrade it to 7.0(4)N1(1). We are ready for disruptive upgrade.
Post uploading 7.0(4)N1(1) image in device it has given additional information message as "LACP: Upgrade will be disruptive as 0 switch ports and 28 fex ports are not upgrade ready!!"
Need to understand upgrade impact on switch/FEX.
SWITCH1# sh install all impact kickstart bootflash:n5000-uk9-kickstart.7.0.4.N1.1.bin system bootflash:n5000-uk9.7.0.4.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.7.0.4.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.0.4.N1.1.bin for boot variable "system".
Verifying image type.
[########### ] 50%
Extracting "system" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.7.0.4.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset Incompatible image
101 yes disruptive reset Incompatible image
102 yes disruptive reset Incompatible image
103 yes disruptive reset Incompatible image
Images will be upgraded according to following table:
Module Image Running-Version New-Version Upg-Required
1 system 5.0(2)N2(1) 7.0(4)N1(1) yes
1 kickstart 5.0(2)N2(1) 7.0(4)N1(1) yes
1 bios v1.8.0(10/06/2010) v3.6.0(05/09/2012) yes
101 fexth 5.0(2)N2(1) 7.0(4)N1(1) yes
102 fexth 5.0(2)N2(1) 7.0(4)N1(1) yes
103 fexth 5.0(2)N2(1) 7.0(4)N1(1) yes
1 power-seq v3.0 v5.0 yes
1 uC v1.0.0.14 v1.0.0.14 no
Additional info for this installation:
Switch is having three FEX's connected to it.
10-12-2015 01:41 AM
Have you managed to upgrade directly from 5.0(2)N2(1) to 7.0(4)N1(1) ?
As per cisco documentation you should follow intermediate upgrade.
We are also planning to upgrade from 5.0(3)N2(2) to 7.0(6)N1(1).
10-12-2015 01:43 AM
If you see the compatibility check results, it says incompatible image.
10-12-2015 07:27 AM
Hi Ahmed,
I would plan to go to 7.0.7 release as it has a few more critical bug fixes.
Check table 6 @ the link below for Supported Upgrade and Downgrade Paths
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/release/notes/7x/Nexus5500_Release_Notes_7x.html#pgfId-584371
-Raj
