Cisco Nexus 5596UP SFP Problem
yucelbasoglu
Beginner
Beginner
Hi All,
We are using Cisco Nexus 5596UP on DC.
we want to use 1g-mm gbic for fiber connection, but do not link up
sh int 1/29 trans det
    transceiver is present
    type is 1000base-SX
    name is CISCO-FINISAR
    part number is FTRJ-8519-7D-CSC
    revision is --
    serial number is FNS0841A2RK
    nominal bitrate is 1200 MBit/sec
    Link length supported for 50/125um fiber is 550 m
    Link length supported for 62.5/125um fiber is 300 m
    cisco id is --
    cisco extended id number is 4
   Transceiver calibration is invalid
sh int eth 1/29
Ethernet1/29 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 0005.73e8.bea4 (bia 0005.73e8.bea4)
  Description: Zer_fiber
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 0/255, txload 1/255, rxload 1/255
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 07:11:12
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  928 multicast packets  0 broadcast packets
    928 input packets  6764 bytes
    0 jumbo packets  0 storm suppression bytes
    0 giants  928 input error  0 short frame  0 overrun   0 underrun
    0 watchdog  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
10 Replies 10
Collin Clark
Advisor
Advisor
Try entering-
int e1/29
speed 1000
duplex full
port settings have already been in the same situation
Without knowing what version of nxos you are running, please see the following data sheet regarding new support optics supported in Nxos release 6.0 for the 7k, You will see that this includes the glc-sx-mm:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/prodcut_bulletin_c25-688075.html
Unfortunately there is no reference for supported Nxos release for the same optic within the 5500 series, see attached data sheet, although the earliest support release is 5.0.3 for the 55k, what version are you running?
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
Allan
I've since looked back through the release notes and have found that the earliest supported release for the glc-sx-mm SFP is 5.0.3N1(1):
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_1_3_N1_1/Nexus5000_Release_Notes_5_1_3_N1.html#wp383223
Allan
no negotiate auto
usually works on 1000G optic(common issue)
js
We are using 1000Base-SX SFP in N7K with release 6.0.2,
But, we can't use 1000Base-SX in 5596UP with release 5.0(3)N2(2b)
1000Base-SX writes are supported on the web page you suggested. However, in accordance with the following configuration does not work.
sh run int eth1/29
interface Ethernet1/29
  switchport access vlan 645
  speed 1000
  duplex full
sh int status | inc 1/29
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/29       ---          notconnec 645       full    1000    1/10g
sh int eth 1/29
Ethernet1/29 is down (Link not connected) - But link connected...
  Description: ---
  Encapsulation ARPA
  Port mode is access
sh int eth 1/29 transceiver details
Ethernet1/29
    type is 1000base-SX
    revision is --
    cisco id is --
thank you for your interest
Yücel
Have you tried another SFP or different fibre uplink? The transceiver is certainly recognised and passes the validation, the nx-os appears to be supported, so it possible that this a different physical issue. What are you connecting or uplinking to?
Allan.
I've tried eight different gbic
SFP is working on N7K, but on the core switch, the customer do not want to link to.
However, the end connected to customer switch. I will check again tomorrow customer side.
In addition, the test will N7K connectivity on the uplink.
Thank you very much for your interest.
yucelbasoglu
Beginner
Beginner
i've tried on N7K. It's working on N7K with same gbic and fiber link.
But, it's not working on N5K.
I will open a case for this problem..
Did you solve this issue?
I have same problem. Is SFP 1Gbase-CISCO-FINISAR is compatible with  Nexus 5600?
Recognize Your Peers
