Cisco Prime 2.2
Darren Mitchell
Hi there,
I wanted to know if Scrutinizer\Net Flow can be plugged into Cisco Prime Infrasstructure 2.2 using Application Visibility and Control section in Prime and if so what is the best way to do this.
Many thanks,
DM
Thomas Johnston
Have you tried to export Netflow data directly from the controllers to Scrutinizer or are you trying to avoid having to do that?
Thanks for reply Thomas,I am trying to avoid that.
Have you used  Scrutinizer in the past?
This discussion has been reposted from Additional Communities to the Cisco Prime Network Services Controller community.
