Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Prime 3.1 with UCS 5108
Amjad Hamayel
Hi All,
i have Cisco Prime 3.1 with UCS license and 5108 blade , i need to add blades to prime
what is the IP should i enter in the prime ? is it CIMC or Fabric Interconnect cluster IP ?
Kirk J
Greetings.
You are going to want to add the 2 node IPs of the FIs and the Cluster IP/VIP.
The cluster VIP is what advertises the OID range for the compute and chassis devices in SNMP.
Kirk...
