04-07-2015 06:00 AM - edited 03-01-2019 07:52 AM
I am seeing the following message in UCS Central about HA NOT READY
Cluster Id: 0x819cae86c88f11e4-0x8fb4d5434d9b9e52 Start time: Tue Mar 24 12:08:20 2015 Last election time: Tue Mar 24 12:08:50 2015 A: UP, PRIMARY B: UP, SUBORDINATE A: memb state UP, lead state PRIMARY, mgmt services state: UP B: memb state UP, lead state SUBORDINATE, mgmt services state: UP heartbeat state PRIMARY_OK HA NOT READY Waiting for response from device. Device count, expected: 2, active: 0 Detailed state of the device selected for HA quorum data: Device 1009, serial: 14713e4e-929e-11e3-aa5e-002a6a7fa904, state: inactive Device 1008, serial: 7cafb282-b1ed-11e4-a520-8c604f230301, state: inactive Quorum data local IO failure: 14713e4e-929e-11e3-aa5e-002a6a7fa904 READ_FAILED, error: GENERAL, error code: 32767, error count: 1348947 Quorum data local IO failure: 7cafb282-b1ed-11e4-a520-8c604f230301 READ_FAILED, error: GENERAL, error code: 32767, error count: 1348947 Warning: there are pending I/O errors on one or more devices, failover may not complete
04-07-2015 06:07 AM
Also the only way for me to cluster force primary is to shutdown the pirmary node and wait for the secondary to notice the peer is down
04-07-2015 06:41 AM
The management services on each node are all running
show pmon state SERVICE NAME STATE RETRY(MAX) CORE ------------ ----- ---------- ---- pmon running N/A N/A core-svc_cor_dme running 0(4) no service-reg-svc_reg_dme running 0(4) no core-svc_cor_secAG running 0(4) no operation-mgr-svc_ops_imgMgmtAG running 0(4) no resource-mgr-svc_rsrcMgr_dme running 0(4) no identifier-mgr-svc_idm_dme running 0(4) no central-mgr-svc_centralMgr_dme running 0(4) no service-reg-svc_sam_controller running 0(4) no policy-mgr-svc_pol_dme running 0(4) no sam_cores_mon.sh running 0(4) no core-svc_cor_controllerAG running 0(4) no operation-mgr-svc_ops_dme running 0(4) no service-reg-svc_sam_licenseAG running 0(4) no policy-mgr-svc_sam_pkiAG running 0(4) no core-httpd.sh running 0(4) no stats-mgr-svc_statsMgr_dme running 0(4) no core-svc_cor_sessionmgrAG running 0(4) no
I can ping the two registered domains from both nodes
10-19-2015 07:50 AM
I have the same problem....
VPLUCEMADPE01-A# show cl
cli clock cluster
VPLUCEMADPE01-A# show cluster state
Cluster Id: 0x8b736a1e766611e5-0xa29e69b27d244196
A: UP, PRIMARY
B: UP, SUBORDINATE
HA NOT READY
No device connected to this VM
I can't connect to Web-Management to VIP
Thank you
04-18-2016 12:17 PM
what do you get if you do
show cluster extended-state
