Showing results forĀ
Search instead forĀ
Did you mean:Ā
compatibility of X2-10G-LR Module with SFP-10G-LR
ayounas
I have cisco 6513 Core switch, having module  WS-X6816-10G-2T / WS-X6816-10GE(baseboard) I need 10G modules for it. Will X2-10GB-LR be compatible with it? also on the Access Switch side I will use Cisco SFP-10G-LR, will it work ok with X2-10G-LR?
@cisco
balaji.bandi
I suggest both sides should be the same for a good outcome - SFP-10G -LR standard with Single-mode Fibre should work both sides.
If you like to use - X2-10G-LR
Look compatible matrix :
https://tmgmatrix.cisco.com/
BB
