configure sun cluster on nexus 9k
sufyan.a1
I have two sun servers connected to two nexus 9k, where each server is connected to both nexus, when I shutdown the port that connected to MPLS, the sun cluster is going to down, where the sun servers are connected to local nexus.
is there any special configuration for sun cluster on nexus.
regards,
6 Replies 6
Rick1776
Level 5
Level 5
Can you give a little more detail.
What version fo NX-OS are you running
Is there a diagram from this environment
Can you paste the configuration for the Nexus 9K switch to see how the ports are configured
SUN Servers
How are the ports configured Layer 2 or Layer 3?
Are you using a NCP or manually configuring the ports?
Hi Rick,
the version for  NX-OS is 7.0(3)I1(2), for diagram see the attached. for SUN server we just give the port IP address I don't know if the port is configured L2 or L3,
for configurations on NEXUS see below
Core 1
Amm-Core-SW1# sh run int e2/33
!Command: show running-config interface Ethernet2/33
!Time: Tue May 15 08:29:39 2018
version 7.0(3)I1(2)
  description CAM1
  switchport
  switchport access vlan 32
  spanning-tree port type edge
  speed 1000
  duplex full
  no shutdown
Amm-Core-SW1# sh run int e2/34
!Command: show running-config interface Ethernet2/34
!Time: Tue May 15 08:29:44 2018
version 7.0(3)I1(2)
  switchport
  speed 1000
  duplex full
  no shutdown
Core 2
Amm-Core-SW2# sh run int e2/24
!Command: show running-config interface Ethernet2/24
!Time: Tue May 15 08:45:27 2018
version 7.0(3)I1(2)
  switchport
  speed 1000
  duplex full
  no shutdown
Amm-Core-SW2# sh run int e2/25
!Command: show running-config interface Ethernet2/25
!Time: Tue May 15 08:45:30 2018
version 7.0(3)I1(2)
  switchport
  speed 1000
  duplex full
  no shutdown
The ports are configured with Layer 2 only as this switchport mode access.
Nexus 9500 has the ability to form a vPC to make both links active.
Is the 3845 Router only connected to only Nexus 9500
Does the Sun Servers get their IP addresses from the router or are the configured statically.
Can you send the output from show ip interface brief and sho ip route on both Nexus 9500's
yes the router is connected to one Nexus 9500, the SUN server get IP manually, and finally please find below the output from two cores:
Core 1
 sh ip int brief
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
Vlan20               10.20.1.12      protocol-up/link-up/admin-up
Vlan32               10.20.32.12     protocol-up/link-up/admin-up
Vlan33               10.20.33.12     protocol-up/link-up/admin-up
Vlan34               10.20.34.2      protocol-up/link-up/admin-up
Vlan35               10.20.35.253    protocol-up/link-up/admin-up
Vlan50               10.20.50.1      protocol-up/link-up/admin-up
Vlan64               10.20.64.12     protocol-up/link-up/admin-up
Vlan65               10.20.65.2      protocol-up/link-up/admin-up
Vlan68               10.20.68.2      protocol-up/link-up/admin-up
Vlan70               10.20.70.2      protocol-up/link-up/admin-up
Vlan72               10.20.72.2      protocol-up/link-up/admin-up
Vlan73               10.20.73.2      protocol-up/link-up/admin-up
Vlan74               10.20.74.2      protocol-up/link-up/admin-up
Vlan76               10.20.76.2      protocol-up/link-up/admin-up
Vlan79               10.20.79.2      protocol-up/link-up/admin-up
Vlan195              10.20.7.13      protocol-up/link-up/admin-up
Vlan200              10.20.63.2      protocol-up/link-up/admin-up
Vlan252              10.252.1.240    protocol-up/link-up/admin-up
Vlan254              10.254.1.240    protocol-up/link-up/admin-up
Vlan300              10.20.0.251     protocol-down/link-down/admin-up
Lo0                  10.20.0.1       protocol-up/link-up/admin-up
 sh ip route
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
0.0.0.0/0, ubest/mbest: 1/0
    *via 10.20.7.11, [1/0], 15w0d, static
10.20.0.1/32, ubest/mbest: 2/0, attached
    *via 10.20.0.1, Lo0, [0/0], 33w3d, local
    *via 10.20.0.1, Lo0, [0/0], 33w3d, direct
10.20.0.2/32, ubest/mbest: 1/0
    *via 10.20.50.2, Vlan50, [110/101], 15w0d, ospf-1, intra
10.20.0.3/32, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/101], 13w6d, ospf-1, intra
10.20.0.4/32, ubest/mbest: 1/0
    *via 10.20.50.4, Vlan50, [110/101], 15w0d, ospf-1, intra
10.20.0.5/32, ubest/mbest: 1/0
    *via 10.20.50.4, Vlan50, [110/102], 15w0d, ospf-1, intra
10.20.0.11/32, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/113], 6d16h, ospf-1, intra
10.20.0.13/32, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/102], 1w0d, ospf-1, intra
10.20.0.16/32, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/102], 3d22h, ospf-1, intra
10.20.0.23/32, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/102], 5w4d, ospf-1, intra
10.20.1.0/24, ubest/mbest: 1/0, attached
    *via 10.20.1.12, Vlan20, [0/0], 33w3d, direct
10.20.1.11/32, ubest/mbest: 1/0, attached
    *via 10.20.1.11, Vlan20, [0/0], 33w3d, hsrp
10.20.1.12/32, ubest/mbest: 1/0, attached
    *via 10.20.1.12, Vlan20, [0/0], 33w3d, local
10.20.7.0/24, ubest/mbest: 1/0, attached
    *via 10.20.7.13, Vlan195, [0/0], 33w3d, direct
10.20.7.12/32, ubest/mbest: 1/0, attached
    *via 10.20.7.12, Vlan195, [0/0], 33w3d, hsrp
10.20.7.13/32, ubest/mbest: 1/0, attached
    *via 10.20.7.13, Vlan195, [0/0], 33w3d, local
10.20.30.0/23, ubest/mbest: 1/0
10.20.32.0/24, ubest/mbest: 1/0, attached
    *via 10.20.32.12, Vlan32, [0/0], 33w3d, direct
10.20.32.11/32, ubest/mbest: 1/0, attached
    *via 10.20.32.11, Vlan32, [0/0], 33w3d, hsrp
10.20.32.12/32, ubest/mbest: 1/0, attached
    *via 10.20.32.12, Vlan32, [0/0], 33w3d, local
10.20.33.0/24, ubest/mbest: 1/0, attached
    *via 10.20.33.12, Vlan33, [0/0], 33w3d, direct
10.20.33.11/32, ubest/mbest: 1/0, attached
    *via 10.20.33.11, Vlan33, [0/0], 33w3d, hsrp
10.20.33.12/32, ubest/mbest: 1/0, attached
    *via 10.20.33.12, Vlan33, [0/0], 33w3d, local
10.20.34.0/24, ubest/mbest: 1/0, attached
    *via 10.20.34.2, Vlan34, [0/0], 33w3d, direct
10.20.34.1/32, ubest/mbest: 1/0, attached
    *via 10.20.34.1, Vlan34, [0/0], 33w3d, hsrp
10.20.34.2/32, ubest/mbest: 1/0, attached
    *via 10.20.34.2, Vlan34, [0/0], 33w3d, local
10.20.35.0/24, ubest/mbest: 1/0, attached
    *via 10.20.35.253, Vlan35, [0/0], 33w3d, direct
10.20.35.1/32, ubest/mbest: 1/0, attached
    *via 10.20.35.1, Vlan35, [0/0], 33w3d, hsrp
10.20.35.253/32, ubest/mbest: 1/0, attached
    *via 10.20.35.253, Vlan35, [0/0], 33w3d, local
10.20.50.0/24, ubest/mbest: 1/0, attached
    *via 10.20.50.1, Vlan50, [0/0], 15w0d, direct
10.20.50.1/32, ubest/mbest: 1/0, attached
    *via 10.20.50.1, Vlan50, [0/0], 15w0d, local
10.20.63.0/24, ubest/mbest: 1/0, attached
    *via 10.20.63.2, Vlan200, [0/0], 33w3d, direct
10.20.63.1/32, ubest/mbest: 1/0, attached
    *via 10.20.63.1, Vlan200, [0/0], 33w3d, hsrp
10.20.63.2/32, ubest/mbest: 1/0, attached
    *via 10.20.63.2, Vlan200, [0/0], 33w3d, local
10.20.64.0/24, ubest/mbest: 1/0, attached
    *via 10.20.64.12, Vlan64, [0/0], 33w3d, direct
10.20.64.11/32, ubest/mbest: 1/0, attached
    *via 10.20.64.11, Vlan64, [0/0], 33w3d, hsrp
10.20.64.12/32, ubest/mbest: 1/0, attached
    *via 10.20.64.12, Vlan64, [0/0], 33w3d, local
10.20.65.0/24, ubest/mbest: 1/0, attached
    *via 10.20.65.2, Vlan65, [0/0], 33w3d, direct
10.20.65.1/32, ubest/mbest: 1/0, attached
    *via 10.20.65.1, Vlan65, [0/0], 33w3d, hsrp
10.20.65.2/32, ubest/mbest: 1/0, attached
    *via 10.20.65.2, Vlan65, [0/0], 33w3d, local
10.20.68.0/24, ubest/mbest: 1/0, attached
    *via 10.20.68.2, Vlan68, [0/0], 33w3d, direct
10.20.68.1/32, ubest/mbest: 1/0, attached
    *via 10.20.68.1, Vlan68, [0/0], 33w3d, hsrp
10.20.68.2/32, ubest/mbest: 1/0, attached
    *via 10.20.68.2, Vlan68, [0/0], 33w3d, local
10.20.70.0/24, ubest/mbest: 1/0, attached
    *via 10.20.70.2, Vlan70, [0/0], 33w3d, direct
10.20.70.1/32, ubest/mbest: 1/0, attached
    *via 10.20.70.1, Vlan70, [0/0], 33w3d, hsrp
10.20.70.2/32, ubest/mbest: 1/0, attached
    *via 10.20.70.2, Vlan70, [0/0], 33w3d, local
10.20.72.0/24, ubest/mbest: 1/0, attached
    *via 10.20.72.2, Vlan72, [0/0], 33w3d, direct
10.20.72.1/32, ubest/mbest: 1/0, attached
    *via 10.20.72.1, Vlan72, [0/0], 33w3d, hsrp
10.20.72.2/32, ubest/mbest: 1/0, attached
    *via 10.20.72.2, Vlan72, [0/0], 33w3d, local
10.20.73.0/24, ubest/mbest: 1/0, attached
    *via 10.20.73.2, Vlan73, [0/0], 15w3d, direct
10.20.73.1/32, ubest/mbest: 1/0, attached
    *via 10.20.73.1, Vlan73, [0/0], 15w3d, hsrp
10.20.73.2/32, ubest/mbest: 1/0, attached
    *via 10.20.73.2, Vlan73, [0/0], 15w3d, local
10.20.74.0/24, ubest/mbest: 1/0, attached
    *via 10.20.74.2, Vlan74, [0/0], 33w3d, direct
10.20.74.1/32, ubest/mbest: 1/0, attached
    *via 10.20.74.1, Vlan74, [0/0], 33w3d, hsrp
10.20.74.2/32, ubest/mbest: 1/0, attached
    *via 10.20.74.2, Vlan74, [0/0], 33w3d, local
10.20.76.0/24, ubest/mbest: 1/0, attached
    *via 10.20.76.2, Vlan76, [0/0], 33w3d, direct
10.20.76.1/32, ubest/mbest: 1/0, attached
    *via 10.20.76.1, Vlan76, [0/0], 33w3d, hsrp
10.20.76.2/32, ubest/mbest: 1/0, attached
    *via 10.20.76.2, Vlan76, [0/0], 33w3d, local
10.20.79.0/24, ubest/mbest: 1/0, attached
    *via 10.20.79.2, Vlan79, [0/0], 33w3d, direct
10.20.79.1/32, ubest/mbest: 1/0, attached
    *via 10.20.79.1, Vlan79, [0/0], 33w3d, hsrp
10.20.79.2/32, ubest/mbest: 1/0, attached
    *via 10.20.79.2, Vlan79, [0/0], 33w3d, local
10.20.129.0/24, ubest/mbest: 1/0
10.20.130.0/23, ubest/mbest: 1/0
10.20.132.0/24, ubest/mbest: 1/0
10.20.134.0/24, ubest/mbest: 1/0
10.20.135.0/24, ubest/mbest: 1/0
10.20.150.0/24, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/102], 6d16h, ospf-1, intra
10.20.162.0/24, ubest/mbest: 1/0
10.20.163.0/24, ubest/mbest: 1/0
10.20.164.0/24, ubest/mbest: 1/0
10.20.165.0/24, ubest/mbest: 1/0
10.20.166.0/24, ubest/mbest: 1/0
10.20.167.0/24, ubest/mbest: 1/0
10.20.168.0/24, ubest/mbest: 1/0
10.20.169.0/24, ubest/mbest: 1/0
10.20.170.0/24, ubest/mbest: 1/0
10.20.171.0/24, ubest/mbest: 1/0
10.20.172.0/24, ubest/mbest: 1/0
10.20.173.0/24, ubest/mbest: 1/0
10.20.174.0/24, ubest/mbest: 1/0
10.20.178.0/24, ubest/mbest: 1/0
10.20.179.0/24, ubest/mbest: 1/0
10.20.180.0/24, ubest/mbest: 1/0
10.20.181.0/24, ubest/mbest: 1/0
10.20.182.0/24, ubest/mbest: 1/0
10.20.183.0/24, ubest/mbest: 1/0
10.20.184.0/24, ubest/mbest: 1/0
10.20.185.0/24, ubest/mbest: 1/0
10.20.186.0/24, ubest/mbest: 1/0
10.20.187.0/24, ubest/mbest: 1/0
10.20.189.0/24, ubest/mbest: 1/0
10.20.190.0/24, ubest/mbest: 1/0
10.20.191.0/24, ubest/mbest: 1/0
10.20.192.0/24, ubest/mbest: 1/0
10.20.193.0/24, ubest/mbest: 1/0
10.20.230.0/24, ubest/mbest: 1/0
10.20.250.0/24, ubest/mbest: 1/0
10.252.1.0/24, ubest/mbest: 1/0, attached
    *via 10.252.1.240, Vlan252, [0/0], 33w3d, direct
10.252.1.1/32, ubest/mbest: 1/0, attached
    *via 10.252.1.1, Vlan252, [0/0], 33w3d, hsrp
10.252.1.240/32, ubest/mbest: 1/0, attached
    *via 10.252.1.240, Vlan252, [0/0], 33w3d, local
10.254.1.0/24, ubest/mbest: 1/0, attached
    *via 10.254.1.240, Vlan254, [0/0], 33w3d, direct
10.254.1.1/32, ubest/mbest: 1/0, attached
    *via 10.254.1.1, Vlan254, [0/0], 33w3d, hsrp
10.254.1.240/32, ubest/mbest: 1/0, attached
    *via 10.254.1.240, Vlan254, [0/0], 33w3d, local
10.254.2.0/24, ubest/mbest: 1/0
    *via 10.20.50.4, [1/0], 15w0d, static
172.16.1.0/30, ubest/mbest: 1/0
    *via 10.20.50.3, Vlan50, [110/112], 6d16h, ospf-1, intra
192.1.4.0/24, ubest/mbest: 1/0
192.168.5.0/24, ubest/mbest: 2/0
    *via 10.20.50.4, Vlan50, [110/101], 13w6d, ospf-1, intra
Core 2
sh ip int brief
Vlan20               10.20.1.13      protocol-up/link-up/admin-up
Vlan32               10.20.32.13     protocol-up/link-up/admin-up
Vlan33               10.20.33.13     protocol-up/link-up/admin-up
Vlan34               10.20.34.3      protocol-up/link-up/admin-up
Vlan35               10.20.35.254    protocol-up/link-up/admin-up
Vlan50               10.20.50.2      protocol-up/link-up/admin-up
Vlan64               10.20.64.13     protocol-up/link-up/admin-up
Vlan65               10.20.65.3      protocol-up/link-up/admin-up
Vlan68               10.20.68.3      protocol-up/link-up/admin-up
Vlan70               10.20.70.3      protocol-up/link-up/admin-up
Vlan72               10.20.72.3      protocol-up/link-up/admin-up
Vlan73               10.20.73.3      protocol-up/link-up/admin-up
Vlan74               10.20.74.3      protocol-up/link-up/admin-up
Vlan76               10.20.76.3      protocol-up/link-up/admin-up
Vlan79               10.20.79.3      protocol-up/link-up/admin-up
Vlan195              10.20.7.14      protocol-up/link-up/admin-up
Vlan200              10.20.63.3      protocol-up/link-up/admin-up
Vlan252              10.252.1.241    protocol-up/link-up/admin-up
Vlan254              10.254.1.241    protocol-up/link-up/admin-up
Lo0                  10.20.0.2       protocol-up/link-up/admin-up
sh ip route
10.20.0.1/32, ubest/mbest: 1/0
    *via 10.20.50.1, Vlan50, [110/41], 15w0d, ospf-1, intra
10.20.0.2/32, ubest/mbest: 2/0, attached
    *via 10.20.0.2, Lo0, [0/0], 33w3d, local
    *via 10.20.0.2, Lo0, [0/0], 33w3d, direct
    *via 10.20.50.3, Vlan50, [110/41], 13w6d, ospf-1, intra
    *via 10.20.50.4, Vlan50, [110/41], 16w0d, ospf-1, intra
    *via 10.20.50.4, Vlan50, [110/42], 16w0d, ospf-1, intra
    *via 10.20.50.3, Vlan50, [110/53], 6d16h, ospf-1, intra
    *via 10.20.50.3, Vlan50, [110/42], 1w0d, ospf-1, intra
    *via 10.20.50.3, Vlan50, [110/42], 3d22h, ospf-1, intra
    *via 10.20.50.3, Vlan50, [110/42], 5w4d, ospf-1, intra
    *via 10.20.1.13, Vlan20, [0/0], 33w3d, direct
10.20.1.13/32, ubest/mbest: 1/0, attached
    *via 10.20.1.13, Vlan20, [0/0], 33w3d, local
    *via 10.20.7.14, Vlan195, [0/0], 33w3d, direct
10.20.7.14/32, ubest/mbest: 1/0, attached
    *via 10.20.7.14, Vlan195, [0/0], 33w3d, local
    *via 10.20.32.13, Vlan32, [0/0], 33w3d, direct
10.20.32.13/32, ubest/mbest: 1/0, attached
    *via 10.20.32.13, Vlan32, [0/0], 33w3d, local
    *via 10.20.33.13, Vlan33, [0/0], 33w3d, direct
10.20.33.13/32, ubest/mbest: 1/0, attached
    *via 10.20.33.13, Vlan33, [0/0], 33w3d, local
    *via 10.20.34.3, Vlan34, [0/0], 33w3d, direct
10.20.34.3/32, ubest/mbest: 1/0, attached
    *via 10.20.34.3, Vlan34, [0/0], 33w3d, local
    *via 10.20.35.254, Vlan35, [0/0], 33w3d, direct
10.20.35.254/32, ubest/mbest: 1/0, attached
    *via 10.20.35.254, Vlan35, [0/0], 33w3d, local
    *via 10.20.50.2, Vlan50, [0/0], 33w3d, direct
10.20.50.2/32, ubest/mbest: 1/0, attached
    *via 10.20.50.2, Vlan50, [0/0], 33w3d, local
    *via 10.20.63.3, Vlan200, [0/0], 33w3d, direct
10.20.63.3/32, ubest/mbest: 1/0, attached
    *via 10.20.63.3, Vlan200, [0/0], 33w3d, local
    *via 10.20.64.13, Vlan64, [0/0], 33w3d, direct
    *via 10.20.64.11, Vlan64, [0/0], 17w3d, hsrp
10.20.64.13/32, ubest/mbest: 1/0, attached
    *via 10.20.64.13, Vlan64, [0/0], 33w3d, local
    *via 10.20.65.3, Vlan65, [0/0], 33w3d, direct
    *via 10.20.65.1, Vlan65, [0/0], 17w3d, hsrp
10.20.65.3/32, ubest/mbest: 1/0, attached
    *via 10.20.65.3, Vlan65, [0/0], 33w3d, local
    *via 10.20.68.3, Vlan68, [0/0], 33w3d, direct
10.20.68.3/32, ubest/mbest: 1/0, attached
    *via 10.20.68.3, Vlan68, [0/0], 33w3d, local
    *via 10.20.70.3, Vlan70, [0/0], 33w3d, direct
10.20.70.3/32, ubest/mbest: 1/0, attached
    *via 10.20.70.3, Vlan70, [0/0], 33w3d, local
    *via 10.20.72.3, Vlan72, [0/0], 33w3d, direct
    *via 10.20.72.1, Vlan72, [0/0], 18w1d, hsrp
10.20.72.3/32, ubest/mbest: 1/0, attached
    *via 10.20.72.3, Vlan72, [0/0], 33w3d, local
    *via 10.20.73.3, Vlan73, [0/0], 33w3d, direct
10.20.73.3/32, ubest/mbest: 1/0, attached
    *via 10.20.73.3, Vlan73, [0/0], 33w3d, local
    *via 10.20.74.3, Vlan74, [0/0], 33w3d, direct
10.20.74.3/32, ubest/mbest: 1/0, attached
    *via 10.20.74.3, Vlan74, [0/0], 33w3d, local
    *via 10.20.76.3, Vlan76, [0/0], 33w3d, direct
10.20.76.3/32, ubest/mbest: 1/0, attached
    *via 10.20.76.3, Vlan76, [0/0], 33w3d, local
    *via 10.20.79.3, Vlan79, [0/0], 33w3d, direct
10.20.79.3/32, ubest/mbest: 1/0, attached
    *via 10.20.79.3, Vlan79, [0/0], 33w3d, local
    *via 10.20.50.3, Vlan50, [110/42], 6d16h, ospf-1, intra
    *via 10.252.1.241, Vlan252, [0/0], 33w3d, direct
10.252.1.241/32, ubest/mbest: 1/0, attached
    *via 10.252.1.241, Vlan252, [0/0], 33w3d, local
    *via 10.254.1.241, Vlan254, [0/0], 33w3d, direct
10.254.1.241/32, ubest/mbest: 1/0, attached
    *via 10.254.1.241, Vlan254, [0/0], 33w3d, local
    *via 10.20.50.4, [1/0], 16w0d, static
    *via 10.20.50.3, Vlan50, [110/52], 6d16h, ospf-1, intra
    *via 10.20.50.4, Vlan50, [110/41], 13w6d, ospf-1, intra
thank you,
Sufyan
I noticed that the VLAN 32 is configured for HSRP. Can you please send the "show hsrp group #" for vlan 32" and "show run hsrp" configurations.
I'm thinking out loud here but maybe you just change VLAN 32 for the SUN cluster to standard SVI interfaces and let OSFP take care of the forwarding that would fix your issue.
hi
please find below:
core 1
 sh hsrp group ?
  <0-4095>  Group Number
Amm-Core-SW1# sh hsrp group ?
Amm-Core-SW1# sh hsrp group 32
Vlan32 - Group 32 (HSRP-V1) (IPv4)
  Local state is Active, priority 150 (Cfged 150), may preempt
    Forwarding threshold(for vPC), lower: 0 upper: 150
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 1.169000 sec(s)
  Virtual IP address is 10.20.32.11 (Cfged)
  Active router is local
  Standby router is 10.20.32.13 , priority 100 expires in 0.430000 sec(s)
  Authentication text "cisco"
  Virtual mac address is 0000.0c07.ac20 (Default MAC)
  3 state changes, last state change 33w5d
  IP redundancy name is hsrp-Vlan32-32 (default)
 sh run hsrp
!Command: show running-config hsrp
!Time: Sat May 19 09:40:56 2018
version 7.0(3)I1(2)
feature hsrp
interface Vlan32
  hsrp 32
    preempt
    priority 150
    ip 10.20.32.11
Core 2
sh hsrp group 32
  Local state is Standby, priority 100 (Cfged 100)
    Forwarding threshold(for vPC), lower: 0 upper: 100
  Next hello sent in 2.374000 sec(s)
  Active router is 10.20.32.12, priority 150 expires in 7.922000 sec(s)
  Standby router is local
  4 state changes, last state change 33w5d
 sh run hsrp
!Time: Sat May 19 09:44:41 2018
version 7.0(3)I1(2)
feature hsrp
interface Vlan32
  hsrp 32
    ip 10.20.32.11
thanks
