07-30-2015 12:13 PM - edited 03-01-2019 07:58 AM
Hi There
Sorry im posting to the wrong place,
Is there any way to connect a cisco B22 fex blade switch for HP to either a Cisco 93128tx or 9372TX?
I've got spare 40gb QBICS and copper 10GB ports but no sfp+ ports.
As far as I can tell I can't use breakout cables in these models and can't use bidi's with 10gb in the remaining 40gb ports as they only want to run at 40gb.
Any suggestions appreciated
Thanks.
07-31-2015 12:49 AM
According to
The Cisco Nexus 9396PX and 9372PX can be used to connect both 10 and 40 Gigabit Ethernet-equipped fabric extenders, Cisco Nexus B22 Blade Fabric Extenders in Dell and HP blade chassis (not shown), and 10 Gigabit Ethernet-equipped servers and systems such as Cisco UCS. The Cisco Nexus 9372TX, 9396TX, 93120TX, and 93128TX provide excellent connectivity for large numbers 10 Gigabit Ethernet-equipped blade or rack servers equipped with 10GBASE-T ports.
07-31-2015 12:50 AM
Unfortunately the breakout interface is not suppored on the platforms you mention. As per the Breakout Interfaces section of the Nexus 9000 Interface Configuration guide:
Note: The breakout of high bandwidth interfaces (module level or per-port level) are supported only on:
