Showing results forĀ
Search instead forĀ
Did you mean:Ā
Converting VDC type
Ayman Elkady
Dears ,
is it possible to convert a normal VDC from its state to type storage  in N7K .
i believe it did not work on the CLI .
are there any considerations or steps should i take care of ?
i just need the same allocations and same config just want to add the Storage features and make it a storage VDC ?
Best Regards
Ayman Elkady
Rajeshkumar Gatti
Don't think you can convert a normal VDC to storage.
You will have to delete the current VDC and build a new storage type VDC and allocate the same interfaces.
More details on storage VDC on Nexus 7k for referencef you don't have this link.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/fcoe/configuration/guide/b_Cisco_NX-OS_FCoE_Configuration_Guide/storage_vdc_on_cisco_nexus_7000_series_switches.html
-Raj
