Customize Lobby Ambassador View
Hi all,
I have a problem with the following situation:
- Cisco Prime Infrastructure 2.0 (2.0.0.0.294)
- Cisco ACS 5.4 (5.4.0.46.0a)
- 2x Cisco WLAN Controller 5508 in SSO mode
- x APs 2600 Series
All devices are configured properly, I can see the WLC on Prime, etc.
Prime and WLC are added to ACS for TACACS+ Authentication.
Admin users are able to login to Prime with full feature set (root permission).
Lobby Ambassadors can also login to Prime for Guest User creation.
Therefore I have created two Shell Profiles on ACS.
Now I want to create WLAN Guest User with Lobby Ambassador Account (TACACS-authenticated!).
I want to customize the Default Guest User Creation page with a company logo and some default settings (WLAN Profile, Apply to Controller List, set "generate password" to fixed, etc.) to fixed values.
Only thing what Lobby Ambassador can change should be setting the password period (with hours or using calender), guest user name and description.
If I configure a local user on Prime, I can customize the page.
However if I use TACACS user, I am not able to use the customized page.
Can anybody help me with this issue?
THANKS a lot!!!!
edit: problem solved by workaround...
https://supportforums.cisco.com/thread/2201703
BR, Stefan
0 Replies 0
