ā06-27-2011 09:55 AM - edited ā03-01-2019 06:58 AM
What is best practice to design the VLANs in Datacenter, group them by Application or function or group them like Windows Prod, windows backup, unix prod,unix backup... Is there any preffered way or it really doesn't matter.Please share your ideas
Solved! Go to Solution.
ā06-27-2011 11:15 PM
Its a difficult question.
Firstly its not operationally impacting, but it is good administrative behavior if possible in a given organization.
In my experience, the design is mostly driven by need. Different application and technologies have different requirements. Consider that and you might be heading in the right direction.
The type of Comany and Data Center purpose would also play a key part.
hth:)
hth:)
ā06-28-2011 06:50 AM
Thanks for sharing your idea Ruhann.
