02-09-2013 01:19 AM - edited 03-01-2019 07:15 AM
02-28-2013 11:04 PM
Hi Jac
AFAIK, if you need to connect SAN devices to N5k , you might need but SAN space licensing or software upgrade to N5k, i've worked with MDS before to be honest they are more like a standard SAN switch which only used for SAN based network with subsecond latency for FCOE or ISCSI system, regarding your blade server conenction ? are you using fibre or copper ? logical would be connecting them to N2k as you have TOR switch avail but depends on speed requirement 1G/!10G? copper fibre, what sort of N2k , N5k ?
Kumar
03-19-2013 09:15 AM
Blade switches...if u r using UCS u need FI..
If u r using hp u can use cisco b22hp or vc 10 for 10-G, or cisci 3160 for 1 g copper.
N2k does not really connect blade switches due to bpfu guard, u can direclty connect blade switch to n5k of Sfp-10G-SR. I'm sure u r using fet for n2k to n5k connectivty....using n5k had its own issues wen u want to use it for storage specialy if u alreafy have other san switch in ur network or ur san doesnt support fcoe...also it needs UP license to carry fc...
U
Sent from Cisco Technical Support Android App
