DCI and OTV
mohammedrafiq
Please see diagram attached.We need to connect two datacentres and run OTV .two 10 g links between datacentres are dark fiber and configured in Layer 3 port channel ahd also a OTV  join interface.due to some requiremnets OTV vdc has vPC running between each site locally.I have posted my config, please review and see if it can work.I know its not recommend way but we have certain requirmrnts to run this way.
DC1
7k1
interface port-channel100
  description "OTV join link"
  ip address 1.1.1.1/30
interface Overlay0
  otv join-interface port-channel100
  otv extend-vlan 20
  otv use-adjacency-server 1.1.1.1  1.1.1.2 unicast-only
  otv adjacency-server unicast-only
  no shutdown
ip route 0.0.0.0/0 1.1.1.2
otv site-identifier 0001.0001.0001
7K2
same config
DC2
7K1
ip address 1.1.1.2/30
interface Overlay0
otv extend-vlan 20
otv use-adjacency-server 1.1.1.2 1.1.1.1 unicast-only
no shutdown
ip route 0.0.0.0/0 1.1.1.1
otv site-identifier 0002.0002.0002
7K2
same config
10 Replies 10
mwlangedijk
Make sure you PVC domains are different, also there is no local site vlan, you need this for the two 7ks to select an AED
Hi thanks for reply,
vPC domain in both DC's are diffrent.Can you explain bit further that why is necessary , not to have site local vlan?
Currently site local vlan 99 has been configured in all the VDC's in both datacentres.
The two 7K's elect an authoritative edge device over the site vlan, the active AED will forward traffic (assuming you are not loadbalancing). If you don't have a local site vlan it will simply not work, i don't even think the overlay interface will come up without it.
Martijn
Like MWLANGEDIJK said, you need to have site VLAN for OTV edge device to elect AED. I don't see the OTV internal interface configuration and I cannot provide any advise. If you use the command show otv, you can see the status of the site-vlan. Here is a sample output from my lab (BTW, I am using multicast, but the site-vlan config is the same as unicast):
Pri-DC-OTV-1# sh otv
OTV Overlay Information
Site Identifier 0000.0000.0100
Overlay interface Overlay0
VPN name            : Overlay0
VPN state           : UP
Extended vlans      : 10-11 20-21 30-31 40-41 (Total:8)
Control group       : 239.0.0.1
Data group range(s) : 232.1.1.0/24
Join interface(s)   : Po1121 (10.10.101.2)
Site vlan           : 111 (up)
AED-Capable         : Yes
Capability          : Multicast-Reachable
One really import information about site-vlan, it should not be extended over OTV, it is local to each site.
Below is the command guide for your reference:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/otv/command/reference/basics_otv_cmds_external_docbase_0900e4b181582ec7_4container_external_docbase_0900e4b18215d854.html#wp1826603
HTH,
jerry
The site VLAN is configured and OTV is working fine, except below  duplicate address error message.not sure why this error is generated.its the MAC add of int e3/1 which is part of int po100(join int).
""2012 Jan 13 14:34:07 otv2 %ISIS_OTV-4-LAN_DUP_SYSID: isis_otv-default [28740] L1 LAN IIH - Duplicate system ID 4055.3927.d1c2 detected over Overlay0 from 4055.3927.d1c2"""""
otv2(config-if-overlay)#  sh otv
Site Identifier 0002.0002.0002
VPN name            : Overlay0
VPN state           : UP
Extended vlans      : 101 103 105 107 191 193 200 300-303 (Total:11)
Join interface(s)   : Po100 (1.1.1.2)
Site vlan           : 1001 (up)
AED-Capable         : Yes
Capability          : Unicast-Only
Is Adjacency Server : Yes
Adjacency Server(s) : 1.1.1.2 / 1.1.1.1
otv2(config-if-overlay)# sh otv isis
ISIS process : default
VPN: Overlay0
  System ID : 4055.3927.d1c2  IS-Type : L1
  SAP : 439  Queue Handle : 12
  Maximum LSP MTU: 1392
  Graceful Restart enabled. State: Inactive
  Last graceful restart status : none
  Metric-style : advertise(wide), accept(narrow, wide)
  Area address(es) :
    00
  Process is up and running
  VPN ID: 53
  Incremental update routes during SPF run
  Stale routes during non-graceful controlled restart
  Interfaces supported by OTV-IS-IS :
    Overlay0
Authentication type and keychain haven't been configured
Authentication check is specified
  Address family IPv4 unicast :
    Number of interface : 1
    Adjacency check disabled
    Distance : 115
  Address family IPv6 unicast :
    Distance : 115
  Address family MAC unicast :
    Distance : 115
  L1 Next SPF: Inactive
-otv2(config-if-overlay)# sh int e3/1
Ethernet3/1 is up
  Dedicated Interface
  Belongs to Po100
  Hardware: 10000 Ethernet, address: 4055.3927.d1c2 (bia ccef.4823.b349)
  Description: * OTV
  MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 13:40:35
  30 seconds input rate 5040648 bits/sec, 766 packets/sec
  30 seconds output rate 54894728 bits/sec, 4642 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 7.63 Mbps, 894 pps; output rate 32.70 Mbps, 2.83 Kpps
  L3 in Switched:
    ucast: 0 pkts, 0 bytes - mcast: 0 pkts, 0 bytes
  L3 out Switched:
  RX
    3094425998 unicast packets  353521 multicast packets  19 broadcast packets
    3094779539 input packets  3053498432578 bytes
    284395082 jumbo packets  0 storm suppression packets
    0 runts  0 giants  1 CRC  0 no buffer
    1 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    11996399744 unicast packets  353521 multicast packets  21 broadcast packets
    11996753286 output packets  17406552054383 bytes
    433788413 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
  7 interface resets
What software version? 5.2(1)?
jerry
yes, it is 5.2(1)
Regards.
You are hitting the following bug:
CSCtw82691
It is fixed in 5.2(3a).
HTH,
jerry
Hi Jerry,
I think I am facing the same bug in 6.1.2
Could you send me a copy of the bug description? It apprears to be in a protected section of bug tool.
Thank you in advance.
Cheers,
Boris
Hi Boris,
Bug, CSCtw82691 is already fixed in NX-OS 5.2(3a). I don't believe your issue is the same.
jerry
