DCNM 11 Fabric Management query
rushikesh88
We have deployed Cisco DCNM 11(0).1 in Easy Fabric mode.
I have following queries -
1) Can we change "Hostname" of the Fabric devices (Leaf-Spine) centrally through DCNM by using any Job/Template ? If Yes, required steps for the same.
(I can see Job deployment option in"Classic LAN" Mode but not visible in "Easy Fabric" installation mode.)
2) While configuring PVC Peer link between Leaf switches, how does the predefined VPC template knows which are the peer-link interfaces of leaf switches that are connected to each other? Because while configuring VPC peer-link it doesn't ask for interfaces selection option.
Pls find the attachment for reference.
Thanks in advance.
daniel.bloom
Did you ever find out how to change a device hostname in DCNM?
