DCNM Lan Manager problem Empty topology
a.giorgi
Hi everybody:
I have an strange problem
I've installed the DCNM in a Windows 2008 VM
I've configured the web client to discover all my nexus, MDS and Host
Everything looks fine at web client, I get the events, I can see all my switches, etc
Everything looks fine in the SAN manager too. I can see all my MDS
But I can't see anything from the SAN manager
The topology map is empty
I've tryed reinstalling DCNM twice
I start the LAN client, I connect to the right IP address, I tryed with different ports like 80, 8080, but the only port that work is the default port 1099
I've searching this forum, and google also, to see if anybody else has the same problem, with no luck
I've check if the TCP port 1099 is open with netstat -na
I've check if there was a port conflict from the original installation, but I can't found anything
Have anybody a clue of what could be the problem?
Thanks in advance!!
Best regards
a.giorgi
I forget to mention, all services of DCNM are running
aruls
Check you have done a deep discovery of devices in LAN. Go to "DCNM Server Administration->Device Discovery", right click the tasks and select "Deep Discovery". Also ensure devices have valid license.
