11-30-2017 09:59 PM - edited 03-01-2019 08:40 AM
I have a "NFVIS" ENCS-5408 router whose WAN port is connected via /30 address.
Now, this device doesn't seem as intuitive as regular IOS where I set default route for different networks.
How do I set different default-gw so that both mgmt and wan routes are functional?
Thanks.
## Version ##
Cisco Enterprise Network Function Virtualization Infrastructure Software (NFVIS) NFVIS Version: 3.6.2-FC3
## Current routes ##
system settings hostname nfvis system settings mgmt ip address 10.70.0.50 255.255.255.0 system settings wan ip address 192.168.200.128 255.255.255.252 system settings default-gw 10.70.0.1 networks network wan-net bridge wan-br ! networks network lan-net bridge lan-br !
Solved! Go to Solution.
01-05-2018 03:58 PM
Few things to point out.
1. ENCS is a x86 server and not a router.
2. NFVIS is the hypervisor that runs on this server which is not based on IOS-XE
3. You will need to deploy the router - ISRv as a VNF on it.
4. Because you are running a hypervisor on a server, you cannot assign an IP address directly to an interface. You can assign an IP address to a network on a bridge.
Please have a look at the getting started guide to see how to can access NFVIS, set the IP address to it and how to deploy virtual machines/VNFs.
thanks
01-05-2018 03:58 PM
thanks
01-05-2018 04:06 PM
thank you for your time writing this.
01-05-2018 06:02 PM
Not a problem. If you need any help, let me know and we can connect offline to help you with this.
