03-13-2013 02:07 AM - edited 03-01-2019 07:17 AM
Hello Gents
Can somebody explain or help with ref on how Fabric Path multidestination tree converges in case of ISL failures?
F.e. lets assume from picture below that ISL between S100 and S10 has failed. If immidiately after the link failure S200 cannot be notified that S100 is no longer available via Tree 1, S200 may decide to use Tree 1 for frame forwarding, and frame will be dropped on S10. Thus there must be mechanism to almost immediately notify S200 (and probably all the othe leafs) to completely switch to tree 2.
03-13-2013 09:03 AM
What traffic are you referring? Multidestination tree are used for multicast, broadcast and unknown unicast.
In terms of how FP rebuilt the tree (not switch from tree 1 to tree 2), the underlying control protocol ISIS will do the recalcuation when links or switches failed.
HTH,
jerry
03-14-2013 12:47 AM
While Q also addresses broadcast and unknown unicast, generally it refers to multicast (assume multicast sender is located on S200). Ok, as I understand U both topologies Tree1 and Tree2 are also rebuilt during IS-IS convergence?
Thank U
03-14-2013 07:39 PM
That is correct.
jerry
