I have a pair of Nexus 56128 configured with fabric path and vpc+. The Nexus pair has UCS connected downstream using vpc port-channels. When a Vlan is in mode fabricpath, it's ok for the vpc+ peer-link and the vpc port-channel to UCS. However when I changed the vlan to classic Ethernet, it's err-diabled in the vpc port-channels.
Is this the normal behavior of fabric path domain? In other words, CE Vlans and fabric path Vlans cannot use the same Layer 2 path, correct?
If I need to transport CE Vlans and fabric path Vlans from Nexus (fabric path vpc+) to UCS, I have to use a separate non-vpc port-channel for the CE Vlans between each Nexus and UCS?
