JonMoss61263
Beginner
FCoE vfc - Nexus
Hi all, i'm trying to follow this guide to deploy FCoE on our network FCoE Configuration Between VIC Adapter on UCS Rack Server and Nexus 5500 Switch - Cisco
I am ok up until the vfc interfaces on N5k-A and N5k-B in our case we have only one single SAN we want to connect to, so my question is, is a valid design to create vfc1 on N5k-A and vfc1 on N5k-B and assign this to the same vsan on both?  My configuration would look like below :
N5548UP-A# configure terminal
N5548UP-A(config)# vsan database
N5548UP-A(config-vsan-db)#vsan 100
N5548UP-A(config)#exit
N5548UP-A(config)#vlan 100
N5548UP-A(config-vlan)#fcoe vsan 100
N5548UP-A#interface po1
N5548UP-A#description **Port Channel to N5548UP-B**
N5548UP-A#switchport mode trunk
N5548UP-A#switchport trunk allowed vlan 2-100
N5548UP-A#spanning-tree port type network
N5548UP-A#vpc peer-link
N5548UP-A(config)# int vfc 1
N5548UP-A(config-if)# bind interface ethernet 1/1
N5548UP-A(config-if)# switchport trunk allowed vsan 100
N5548UP-A(config-if)# no shut
N5548UP-A(config-if)# exit
N5548UP-A(config-vsan-db)# vsan 100 interface vfc 1
N5548UP-A(config-vsan-db)# end
N5548UP-B# configure terminal
N5548UP-B(config)# vsan database
N5548UP-B(config-vsan-db)#vsan 100
N5548UP-B(config)#exit
N5548UP-B(config)#vlan 100
N5548UP-B(config-vlan)#fcoe vsan 100
N5548UP-B#interface po1
N5548UP-B#description **Port Channel to N5548UP-A**
N5548UP-B#switchport mode trunk
N5548UP-B#switchport trunk allowed vlan 2-100
N5548UP-B#spanning-tree port type network
N5548UP-B#vpc peer-link
N5548UP-B(config)# int vfc 1
N5548UP-B(config-if)# bind interface ethernet 1/1
N5548UP-B(config-if)# switchport trunk allowed vsan 100
N5548UP-B(config-if)# no shut
N5548UP-B(config-if)# exit
N5548UP-B(config-vsan-db)# vsan 100 interface vfc 1
N5548UP-B(config-vsan-db)# end
thanks
0 REPLIES 0
Content for Community-Ad
